1,953
So, buy the L5P bolts along with the cooler? Knowing GM, those suckers will be pricey.
Get the specs on them, Ace Hardware has metric flange bolts for a lot less.
5,920
Can you just cut the bolts down or is the threads to short?
You might be able to but the shank would be rrreeeaaallll close to hitting the threads. You still need two bolts either way
That’s where I’m headed today
5,920
You will need 2 8mmx1.25 120mm long bolts and 3 8mmx1.25 40mm long bolts for the other three mounting bolts of yours are too long. My ace only had 110mm long bolts and they are too short so I ordered 2 in from Allen’s fasteners. Couldn’t find a flanged bolt in that length so you may have to buy GM bolts with the cooler if you want them all to match or change them all out so they match
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
The new cooler is 20mm where the old coolers are 13/16”.
the lml manifold fits quite well. Just need a touch of clearancing on this heat shield mount (bottom rear)
Also, i don’t know if lbz and up will be an issue but lly/lb7 guys, you will need all new bolts. The 3 short ones are too long by about an 1/8” and the two long are wayyyyy longer than your stock ones. I have double stacked washers on the 3 short bolts for now to just hold it in place. You will also need a third bolt for the elbow.
This thing is massive though. Pics don’t do it justice
Thanks again josh for getting this out quick to me :D
Could someone help me with what port my temp sensor needs to be placed in. Which of the Allen plugs is it
5,920
i couldnt find one. its not really tapered nor is it o-ringed. its also metric thread
made my own from one of the factory plugs
LB7 Lover 1994
Know Nothing
Jul 20, 2013
262
Greene County, In
That is an awesome ideal! Will definitely be doing that to mine. I have been scouring all my vendors and have not been able to locate a 20mm- 13/16 adapter any where!
Which of the three plugs is it that it needs to go in?
Bdsankey
4,225
1,330
Larsen, Wisconsin
Why are you trying to go to 13/16? Most temp probes are 1/8npt.
yellowchevy
1,926
82
Louisburg, KS for now
Dumb question and it might have been answered but is the idea to upgrade to the 2020 oil cooler and then you don't need an external radiator style cooler?
JAMES!!!! this question is for you mainly...:D:roflmao:
Yellowchevy
5,920
are you guys trying to find something like this?
https://www.amazon.com/Sensor-Adapter-Water-Boost-M20x1-5/dp/B01NAQW6X8
or this?
https://www.ebay.com/itm/Metric-Fit...-Female-Gauge-Sensor-Adapter-GU-/162518700736
With the lip on the plug, Id think the first one I linked might be a better choice?
top one might work well. i had searched parts stores as at the time, i wasnt going to wait for an adapter to get the engine in and running... that changed :roflmao:. it will need a gasket of some sort for sure.
Yellowchevy
i dont know that yet. Honestly, the issue will become two fold. The bigger cooler will be great at bringing oil temps down at the cost of putting all that heat into the cooling system. If you really want to keep temps down (both coolant and oil), you are going to need more cooling capacity and this cooler but i dont know if it will get rid of the external all together.
when my truck is finally up and running reliably, i plan to do a trip or two before the new truck comes in and i wont be running my external oil cooler (sandwich adapter wont work on the new cooler). After what i saw pulling the hills from the dunes with leaky heads and oil temp staying way down from the aux radiator, i have hope but 80* is not the same as 105-110*. Hopefully its plenty because i dont feel like spending the cash on more parts for the truck when it wont see towing duty hardly at all.
the external is by no means a bad way to go, specially if you keep it out of the cooling stack. its not as efficient but you dont put added heat back into the cooling system and it brings oil temps down a significant amount.
gmduramax
Shits broke
Jun 12, 2008
4,081
252
Nor cal
Yellowchevy
Is this a serious question :roflmao: next will be a oil cooler running across the roof that looks like a light bar :hug:
2,218
or this?
I may be wrong, but from the photos James posted where he dilled and tapped the plug, it looks almost like there is a chamfered edge at the end. And maybe even one on the flange. I would bet this is the means of sealing. The ones you linked to seem to be cut at a 90* and would not seal properly against the internal chanfered surface
James, comments?
5,920
James, comments?
You are correct, hence I suggested a gasket of some sort (copper washer?) that’s hopefully wide enough to seal up. Just don’t know how well that will do under pressure in the long run
