OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Installed a 6 speed trans cooler under my 05 cooler. Thanks to the alligator lines I was able to adapt to the new cooler so easilly. Saving the old cooler for a future fuel cooler.
moparkxracer
2,309
33
Out and about
Big thank you to all the guys at Diesel addiction and Landon. Got my transmission and all that back in, frame molded in traction bar mounts, oil cooler brackets mounted and a few other things finished up.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Thanks. All tig welded 2 1/4" from the manifolds up. Have to tighten the turbine some and swap converters then it will be ready to race.
divemonster
Sep 12, 2014
105
I also got an MBRP 4" turn down exhaust to replace my DIY garage hero edition turn down I made out of a 4" Diamond Eye single rear exit system to clear my swaybar a couple years ago...
Now that the engine and downpipe are in I'll get it installed this weekend, probably today
:D
If any locals (Seattle/Washingtonians) want a good 4" exhaust, you can have that DE downpipe back exhaust
:thumb:
Ship it to NC so these guys will stop picking on my factory exhaust. Lol
2007 classic duramax CCSB with
Automatic 6 speed Allison
624
SMH.. Its got Alabama plates on it...
rgullett83
1,607
Illinois
Continued with trans build, removed fuel tank, all factory hard fuel lines and brake lines, shoved the frame outside to pressure wash it
Sent from my SM-G900H using Tapatalk
Aug 3, 2013
898
Arizona
Drove the truck to school today, put some money into some diesel, and then bought a steel bar thing and some bolt/washers for my custom led light bar mounting behind the grille
e46_330i
140
Youngsville, NC
I keep dropping the ball on sending you pics man I'll get to it hopefully tomorrow when the shop slows down
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I got everything pretty much buttoned up today!
MBRP turn down is on, factory fuel lines removed, replacement lines in, fuel return distribution block is plumbed, fan and shroud are on, cooling stack is in place, upper crossmember and core support at in, hot and cold side pipes are in, air cleaner is in, mishimoto rad hoses are on, engine mounts and grounds are tight all the electrical connections are plugged in...
I somehow or another snapped the tee on the drivers side return line off the #8 injector, but I got a brass tee to replace it...other than that
I just need pit the headlight assembly's and lights on and fill er up with fresh fluids, flush out the coolant system with distilled water and fill up with dex and I'll be on the road again!!!!!!!!!!
:thumb:
:woott:
