Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Finally took the moulding(s)/off the doors today...there are a couple dents under the trim pieces...all in all, I like it, looks cleaner and meaner :thumb:
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
I had a no charging issue with my lbz and that little red box to the left of the driver's battery was all melted into the leads and the alternator wasn't making connection to charge the batteries
X2. Had that happen on my lowered LBZ back in 2010 ^^^
Well the problem I think is something else.. It's throwing p0621 &p0622 codes.. Beer and the lake was calling so I didn't mess with it much
baddaddition
Mar 10, 2013
287
Found another set of Rate parts Gen 2 tie rods on Amazon. For 275$!!!! Been buying em up! This is what they should be factor. These things are huge!!!! uploadfromtaptalk1435399581261.jpg
Sent from my XT1254 using Tapatalk
Pure Diesel
896
154
Ventura County
Put the Sulastic Rubber shackles on the back end. I would say they make the truck ride 50% better. Haven't had a chance to do the washboard freeway yet.
Well I've put about 600 miles on these and I think their worth it. They are a bit pricey. The best way to describe what they do is, when you go over or through dips/bumps it softens the jolt of it. The approach and departure on bridge over passes is much better. The washboard of the freeways is smoother but not gone.
Also put in new upper ball joints. The front end is smooth and doesn't shake again. Didn't realize that they were that bad after 135,000 miles.
matt78
Finally boosted launches
Sep 10, 2012
924
texas
Added a cts to the durahome, all she needs now is my old lift pump on it.
5,835
Changed the oil, cleaned he air filter (gunna need to buy a new one soon), changed the fan clutch, and installed one new coilover shock and stopped till after the late fathers day dinner I'm doing for my dad and father in law.
Gussets added cause we are going to get pretty serious off road here soon
Driver side wrapped up
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
I am interested in doing a coil over swap on my little half ton toy. My knowledge is nill. And my expierence even less.
Is their a certain type you use? What model vehicle are they for? I have a briken t-bar right now and i think a coilover would be amazing for the road coarse...
5,835
When putting coilovers on a rig that was never designed for them, a lot of challenges come up and you gotta have some back knowledge on how suspension works, how to figure spring rate for correct ride height, and lots more. The main ones are spring rate and proper length shock. Yours being a 1500, a lot of people have done it already. You might search around and see what you can find out.
These foxes I had built for my truck. Spec'ed valving, spec'ed shock length, what length hose I wanted for the resi, and different eyelet end as well as a few other things internally. Only thing I wish they had was external rebound adjustment that worked as well as qa1's.
baddaddition
Mar 10, 2013
287
What could one anticipated a set of them just plain coil over cost. Just a set height with a standard rebound rate?
