Off Season Sled Pulling Mods
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
Or find a circuit with loose tracks :rofl:
Our tracks with fpp are like 50/50 good/shit tracks. we seem to hurt something about 50% of the time this year. but we pulled on a few other good tracks with other orgs this year. this was the last tcase, prob had 10 hooks on it.
I guess we could cut the class back to 2007 levels of 600hp 2.8 then we wouldn't break anything!
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
That would be mint. Sounds like something up Empire Diesel's alley.
Or I guess you could adapt the 07.5+ units, maybe they would hold up better?
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
WOW. That thing is flexing like CRAZY!!!!!!!! I have never seen a duramax T-case do that. Even looks to have the MA T-case brase.
ikeG
Oughta Know Better
Apr 19, 2011
2,466
151
Western PA
www.facebook.com
Its the 2nd one he's done that to...
I am not at the point like some are, where 3.0 sounds appealing. But it prob wouldn't take much more breakage to start leaning that way.
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
THe only thing inside that case that broke was the gear that drives the front shaft, which casued the chain to trash the case! Of course the rear pinion broke first, shocking the tcase. The crash happens here at 5:06.
[YOUTUBE]ZyWh0Td2k5g[/YOUTUBE]
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I would assume higher operation noise wont be a concern? I know that's one complaint with the yukon gear sets. But I'm thinking even stronger material like 300M?
05_LLY
Out-A-Time
Aug 7, 2006
1,756
Norvelt, PA
no no worries about noise here. 342 would be ok too, then would only need to make rears set! let me know if its available and how much, id look into it for sure. biggest problem with the 342 is when the pinion dose break it breaks at the splines and puts the pinion gear threw the case everytime. with the slower ratios they just clean the teeth off, change them out and move on till next time! lesser of the 2 evils kinda thing im thinking!
Yellow Jacket
WannaBe Sled Puller
Feb 11, 2009
917
Waterloo, IA
Finally tore engine down, here is a couple pics of the crank. It is cracked about 80% of the way through...
