Sounds like the "Ram is ditching Cummins" rumors that have been going on since, oh probably 1990.:roflmao:
I doubt GM is ditching the Allison.
GM still shows the Allison in powertrain info at work.
At least you know now what the power ratings are going to be.
I wish the Allison was a bit more robust in the HP handling department. Guys with the 6.7 fords are holding 600hp pretty dang easily with their stock trans. Sure, some guys might fry one hear and there, but it doesnt happen often. Not only that, their trans seems to respond to trans tuning a tick better than ours (Buddy of mine has one so I've scoped it out a few times).
In the end no matter what you do to the Ford is going to make it out perform a duramax.I wish the Allison was a bit more robust in the HP handling department. Guys with the 6.7 fords are holding 600hp pretty dang easily with their stock trans. Sure, some guys might fry one hear and there, but it doesnt happen often. Not only that, their trans seems to respond to trans tuning a tick better than ours (Buddy of mine has one so I've scoped it out a few times).
huh?
And Mike, the Ford's trans may be alot to fix, but it doesnt happen very much at all. Especially for the guys only making 500-600hp.
I just did 2 of them at 500 hp. Parts would have cost me 5K without my labor or mark up. I bought new.
from what i keep hearing guys spend on dodge and ford trans to make them hold what you built mine to hold, it sure makes me glad i have an allison.
My buddy spent like $10k on his built trans for his dodge, but said it would hold 1k HP... Still seems like an expensive tranny build to me. I think that price included freight and duties to Canada as well which is where it was built.
We dont need more gears. More than 6-speeds would require a 4th planetary.
Another planetary means more complexity, more weight, more things to break, and more parasitic load on the engine. Not to mention more cost.
Do you want a truck thats heavier, more complicated, potentially less reliable, more expensive, and gets worse fuel economy? I didnt think so.
