Nitrous for dummies?
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,223
369
At Da Beach
Not an answer to your question but, with the hypertech, nitrous isn't going to help much. I doubt it is fueling hard enough for nitrous to do anything. You gotta have fuel to burn to see much improvement. Take that money and spend it on a good EFI Live tune, then you will probably have more power all the time.
Not to mention the truck will run better and you can add a turbo brake. Nitrous is for racing not DD. Get yourself a set of tunes form a reputable tuner and you will be much happier with the end result...
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Thank you to all who posted in this thread. Just read all 9 pages and I will be buying some nitrous stuff so for the single cab. I want to limit myself at the solenoid, so I will be using a .063 NX noid. I want to start small (.030 range) and see where it gets me and go from there.:thumb:
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Quick update,
got my wiring issues figured out on the Zex nitrous kit(WOT TPS/Master Arm)
Running the truck around on 2000Us on 100% injectors, and a 150shot. Cleans up the smoke nicely. :thumb: Started small with a .026 jet and worked my way up.
Based on smoke output, I will be increasing the fuel and the jet size to compensate.
Track next weekend
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Ended up gaining 8mph on a .076 jet. Cleaned up most of the smoke, still need a bigger jet. I also need a lock up box asap. I flip the spray when the converter locks, top of 3rd, so im not gaining as much ET as I want, but gaining MPH. Lots learned today. Got booted for no cage again, so wont be out till after the new year with a cage in the truck.
yamaha537
May 26, 2011
56
New Jersey
Instead of starting a new thread I figured I would just ask my questions in this one, there is a lot of good info in here already.
Im looking into running a small shot on my stock motor.
http://www.jegs.com/i/ZEX-Nitrous/243/82028/10002/-1
They have another NOS brand kit that looks similar but ive heard good reviews on ZEX
that is the kit I am looking at right now, Am I in the ball park of what is needed? Id just run a momentary switch so I can hit it exactly when I want.
I talked to my tuner and he said no need to pull timing back on diesels which ive heard mixed opinions on.
