Next mods?
036.6turbo
747
92
Thanks, I sure hope they do. I’m a little worried as I never registered this pump. I found my invoice from alligator and it was purchased in September. I didn’t think about registering as my first fass on the lmm didn’t give me any hiccups for 3 years..
I never registered mine, they didn't even ask, when I called. But the check ball thing was a known issue and the parts were five / ten bucks tops.
A replacement motor may be a different story.
Josh154
1,220
85
Sioux Falls SD
Got her primed and running! Thanks guys. Pulled hose to cp3 pressurized tank got fuel flowing and running. Fass pump should be here Wednesday as well
Josh154
1,220
85
Sioux Falls SD
Got her running and back at work! Love this setup and Blake’s tunes. Driveability is amazing, so smooth. Intake sounds great, exhaust tone is much better. I am beyond happy!
Dozerboy
4,918
498
TX of course
So if I pull my 1/2” hose off, pressurize tank till fuel flow attach to cp3 and crank I should be good?
FYI I don’t even loosen the line. Just give the batteries a good charge and pressure at the filler neck. You can crank it up to 20sec. Then let the starter cool. The Dmax will pass a ton of air and run still. It’s pretty shocking.
FROGMAN524
613
What would you say was the hardest part of the install and how many hours total did you put into it?
scott_willerscheidt
Jan 30, 2019
27
3
3
gig harbor wa.
PPE manifolds and up pipes. Then mild Tunes
2002 gmc sierra 2500hd quad cab short bed
Zone 3" kit
285/70/17 Nitto Terra Grapplers
17x9 Raceline 930's
S&B intake
3" turbo horn
PPE boost valve
MBRP 3" downpipe
MBRP 4" exhaust
LED conversion
Edge CTS2 with SAS EGT probe
boost auto towing mirrors ( dual function)
fass 90
Digmax
289
Zone 3" kit
17x9 Raceline 930's
S&B intake
3" turbo horn
PPE boost valve
MBRP 3" downpipe
MBRP 4" exhaust
LED conversion
fass 90
????? Have you even read the thread?????
Sent from my SM-G935V using Tapatalk
scott_willerscheidt
Jan 30, 2019
27
3
3
gig harbor wa.
Started reading after I posted. My bad. Delete post
Zone 3" kit
17x9 Raceline 930's
S&B intake
3" turbo horn
PPE boost valve
MBRP 3" downpipe
MBRP 4" exhaust
LED conversion
fass 90
Josh154
1,220
85
Sioux Falls SD
Honestly probably ripping everything apart to get to the cp4. Egr system, stock down pipe, stock cac. Once all of that was out it was cake. Stock y bridge was easy even with turbo in place, cp4 to cp3 was easy, eliminates factory filter and all those lines. Once cp3 was done I only had a couple more hours into it putting y bridge, intercooler pipes and downpipe back in. I had 2 full days into it coming from 100% stock to this. I took my time though, went to the gym both days went out for dinner with my sister and the kids. I did this whole project by myself too.
Here’s a little before and after pic lol.
Josh154
1,220
85
Sioux Falls SD
Zone 3" kit
17x9 Raceline 930's
S&B intake
3" turbo horn
PPE boost valve
MBRP 3" downpipe
MBRP 4" exhaust
LED conversion
fass 90
That will probably be my next mod now with a drop in. I had profab 2” up pipes on the lmm before and really liked them. Couldn’t justify spending the money on them right now, stock turbine can only flow so much air right now
5,930
wouldnt waste the money on them for a drop in.
Josh154
1,220
85
Sioux Falls SD
looks clean i like it, thanks, now this thread is gona cost me $$$$$$$$$$$$:thumb::thumb:
Haha my only goal was to do the cp3. But man I’m so glad I splurged and bought the sdp kit. It’s so nice to do it all at once. Literally everything needed to come off anyways. Sdp is the way to go forsure. Everything fits so nice and the quality is amazing. I had hsp on my lmm and definitely think sdp is better. Also hsp kept promising ship dates and getting behind, I get it being busy and slammed sucks. But just give me a realistic date from the get go. Scott had my kit out not even 24 hours after placing the order
