They should all be out in 2 weeks. I now have even newer clutches to test.
Mike Are you going to announce when they are out and you start selling kits? Very interested in the new setup with the ML-G
Why would they upgrade the c4 but not c3? The c3 has pretty much been the weakest pack since they came out
This is GPZ material?
Update.
So far this has been the best shifting Allison I have ever driven.
I only changed the C3's to the GPZ cause that's all I had left. It's my brand new PR spring.
Are you out sourcing parts?
EVER AS IN EVER FROM 2001 TO PRESENT MODEL YEAR?
What does Peurto Rico have to do with the spring? Are you out sourcing parts?
My lml has always been the best shifting truck I ever drove so I can't wait to make it even better. I don't suppose the spring is one that can be changed by the valve body without pulling the trans? I suspect I will also need the c3 clutches too so might as well put them and the converter in too.
Yes Mack; the best ever. It was a great shifting trans before I touched it and now it's even better and will hold quite a bit of power.
Pressure Regulator spring.
When you get bored you become a real pain in the ass.:roflmao::angel:
Trans must come out for the spring. I would do the C1,C2, and C3 at the same time. Leave the back end alone ( C4 ). Don't even need to pull pan or touch valve body as it has Allisons version of the Transgo already designed into it. I'm making a slight change in the converter flash. This Alli will be the best ever.
That's good news, but it's a long drive to Cali.
