My build
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Is it me or does it start to push through the brakes? Or were you slowly letting off of them and rolling into it?
It pushes thru at 10psi always has....:-/ it's hard to launch. I to what I can to get a solid launch.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
It's also spinning pretty bad gotta let air down a little more and get my center link on correct some suspension issues. It's pullin the front end up pretty bad.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Always see people talking about pushing through the brakes at low boost.. Can't figure that out. My old lbz would hold 25 and never push through.
Good job on getting to where you are! Truck looks great!
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
It depends on the rpm. If you can make 100 psi of boost at 1500 rpm your not going to push through. But if you only make 10 psi at 2400 most trucks will start pushing through the brakes. Of course torque converter stall plays the biggest roll here.
But my main point is, the boost number is completely irrelevant to where or why a truck will "push" through the brakes.
Sent from my SCH-I535 using Tapatalk 2
1,981
You really should go thru your braking system. 1) See if the pads are sticking in the calipers. 2) When was the last time you changed the brake fluid? Thats highly overlooked overall but can be a big problem when we race these trucks. 3) Also change out the fluid thru the hydroboost.
x2 to everything IowaLLY posted.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Thanks for the info, makes sense!
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Yeah we will him just been super busy. Thank you.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
I understand. Thank you for the info
paint94979
Beer Nazi
Sep 18, 2006
11,715
This ^^^
