My build
PACougar
2,105
41
El Dorado Hills, Ca
Cool, I guess my truck, Broviaks truck, Gullets truck all which have made 10sec passes with the ABS fuse pulled for the hell of it..You win
You guys probably also made those passes with helmets on, I don't think it contributed to the pass either :roflmao:
DetailsUnlimited
1,264
Benton, Ar
I have read thru all these threads and regardless if my trucks abs is deactivated under 5 mph. I had the same issues as the rest and pulled the abs and it worked. So what the big F'n deal? Try it or not. Some you ppl bitch to damn much! We are all here to help each other solve their problem or are aren't you?
1,981
Hell, try it. It can't hurt. But quit arguing about it, b/c thats counter productive. I swear some of you just cannot get the DF stink off your posts.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
I ran with ABS fuse in and could leave at 30psi on a single 80mm, ill have to try pulling it when I get the truck back.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,518
503
Central OH
Well, back on track. I saw Katie's truck run here at the dirt drags, not sure if she was driving or not. Sounded good, but didn't look that smooth. Right side of the track blows.
sickdiesel
Apr 22, 2010
1,019
maybe it is a placebo thing, maybe it isnt IDK. but when i dont pull the fuse i can maybe build 15psi, with it pulled i can build 35 easily.
Does it have something to do with me typically forgetting the first pass to pull it and the brakes being cold, then the second pass i pull it and the brakes are warmed up a bit?? Maybe but i typically always forget the pull it the first pass so havent been able to test that theory.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
It was me driving, track was rough as can be it was horrible and didn't help I was only running sleeves. Got my PPE centerlink on today can't wait to hit the track again hoping To get my 60' down and hoping a 12.0 run.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Finally ready to rebuild. ️ can't wait for the season.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Sweet! What are the build plans? What are you doing for air?
twins this season.
What the hell those don't look bent
Haha that's because im awesome. JK.
This block is a spare block Wehrli had in the shop. We wanted to get one to the machine shop asap. He won't actually start tearing mine down till feb. When he's moved into his new shop that way it's not in a million pieces and easily moved.
CAM was ordered its a few weeks out.
Pistons should be there tomorrow (ordered before Christmas lol)
