My build
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Nice patch :thumb:
Next time Try one with out the brakes ;)
picture.php
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
Yeah pretty squirly, what are you using on the front end for bracing? Your Sig only says tie rod sleeves.
The DHD brace made mine launch straight with one finger on the steering wheel.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
Just sleeves at the moment gonna be ordering a link from PPE and Kory has my tuning turned down for my stock bottom end he's sending me new tunes this week. I've only made 5passes on the truck so were still fine tuning
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Thought i saw on Facebook you said it was 12's. And you said you ran 116mph on your 14 second pass? I'm not seeing this info adding up.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
It was the ladies of diesels page that said you ran a 12. Did kory turn it down that much to go from 116mph to 103mph?
Not what I said I said mikes truck ran a 12.0 said my 14.0@110 my mistake was 109. My 2nd pass that night was a red light but the speed was 116mph.
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
boyfriends run 12.0@118mph
S475/stock, 45% nozzles, dual cp3, arp headstuds, Calvin's built Trans and supporting mods.
DaJokr
Slum Lord Extraordinaire
Mar 7, 2013
450
Prince George, BC, Canada
Once she beefs the front end components up. Even with sleeves, I know at 2000rpm on a 150 tune the front end bucks and hops really bad. Needs braces to hold more psi, that would get the 60' down as well.
LWATSON
future trans limpers
Jul 30, 2008
2,587
54
Scotland Neck NC
All I have is braces and sleeves and with DR's have no problem getting consistent 1.6X 60'. Sometimes I get some hop if I go full throttle too early before I'm off the brake good but its usually pretty smooth. I'm also leaving the line at 3000 rpm's.
OregonDMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
I had the cognito braces first then switched to the DHD brace and noticed much better control during a launch regardless of boost level or track surface.
