LB7: Motor Build thread
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Got the Cam and Crank keyways cut last night , so hopefully have some time this weekend to start re-assembling. here is a quick cell pic of the Cam i took this morning . Just dont let your wife catch you putting your dirty camshaft on the washer to take a picture she wont be happy :eek::rofl:
Is it the fact that you take pictures of the dirty shaft or is just because it is on the washing machine that make them mad?:D
I like the green Trent.
Anything else you doing? threaded freeze plugs? New oil pump? Spot weld on the water pump?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Both :D
No not much else , re-using oil pump , What are guys spot welding on the water pump , the gear or nut i assume ? I am pulling off every nut even if i didnt touch it and applying lock tight and re-torquing just to be safe , cant think of much else but am open to sugestions ?
13,765
834
I believe Pat made a post a while back about a water pump impeller that, when it was pulled out of the engine, you could see it had moved on the shaft. Apparently they are only pressed on from the factory, but on the replacement pump he had the impeller TIGed to the shaft.
TrentNell
Jul 7, 2008
7,543
slc tuah
I remember that thread now , thanks i will def do it .
Got all the rotating assembly done tonight , pistons, rods , cam , crank , oil pump ect all in the block now :happy2: hopefully i can keep making good progress this weekend and at least get the short block completely finished , maybe more if some other parts show up .
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
mine has no blow by.:D
Have you done a compression test?
Obviously I wouldnt want Trent to something that is not needed....I feel strongly enough about it on his race motor that I believe it is neccesary.
Maybe because i used forged slugs that it made the difference?
TrentNell
Jul 7, 2008
7,543
slc tuah
here are a few pics so far from what i got done last night
TrentNell
Jul 7, 2008
7,543
slc tuah
Short block is finished and ready to accept heads , have to go see if my valve springs showed up to see if i can finish my heads . I'll tell you what , i cant wait till this is done so i can clean the floor in my shop , after tearing down so many motors lately , and several trans build over the last month , my shop floor is looking pretty pitaful :eek: , getting excited though and think its looking really good , will touch up the block and paint a few things but want to get the heads on first and motor sealed up .
TrentNell
Jul 7, 2008
7,543
slc tuah
WHENS VEGAS!!!?? damnit i never find this stuff out :( I wanna go... even if just to spectate...
As soon as my truck is done , might wait for Dimitri to get his regular cab done too butg i want to go make some runs down the srtip when it is finished , gotta see what the old girl can do :D I will let you know , i was going to invite the whole crew and see who want to go !
TrentNell
Jul 7, 2008
7,543
slc tuah
Trent dont forget to install the wire for the oil press sensor....I always forget:eek:
Thanks for the heads up Simon , i am waiting on my fancy wire loom to show up before i can put any of the wiring on , hopefully i wont forget that now , I probably would have too .
dordtrecht5
Regular Cabs Rock
Jul 21, 2009
900
Wherever I am working
thanks for the thread
one question for you though...are the rods completely balanced to match weight all of them? how many grams do they typically differ coming out of the box new?
Sorry, that I came in late on the thread. Just curious.
