LB7: Motor Build thread
13,765
834
Cut my pistons last night , it was pretty cool , I did all the machining myself so it was fun to learn , just a touch scary because i had never cut a piston before but was really fun to play with the lathe . I have know idea how these are going to work , nor what differs from how other cut there pistons , i did it by what i felt needed to be done , compression should be 15.0 ............ zero off the top............. all taken out of the bowl , and the radius is decent sized IMOP , I did it with hopes of helping with heat . Like i said I am in no way saying this is the best way to do it but i am going to try it, and like they way they turned out .
I still need to cut my key ways ( no time last night ) so maybe I can start re-assembly next weekend .
The pistons look good. Did you measure the bowl volume like we talked about, or did you do something different?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I am going to , I made the stuff to test it but , the CC #'s werent aplicable to use Guys spreadsheat like i thought they were , but Johnboy crunched the #'s and helped us come up with the 2.6 dia. :hug: , now i just want to double check the CC's and figure out the actual compression ratio and see how close we got .
Thanks for for all your help , and if you know a way to figure CC's to actual compression ratio i am all ears :teknology::rofl:
13,765
834
I'll have to sit down and figure it out, but I'll see what I can come up with.
By my calculations, your stock combustion chamber (meaning the volume in the bowl, head, and head gasket) has a volume of 3.06 cu in (50.14 cc). To get a C/R of 15.0:1, you would need your combustion chamber to be 3.60 cu in (58.99 cc). So you would want to take .54 cu in (8.85 cc) out of the bowl area and leave everything else the exact same (same head gasket and same piston protrusion).
wdino73
735
55
Versailles, Ky
Good luck Trent I've been reading the thread, I hope it's abeast when your done, I'm subscribing, I'm sending you all the positive energy I can dude, Oh an thanks for sharing this with us.:thumb: :thumb: :thumb: :happy2:
TrentNell
Jul 7, 2008
7,543
slc tuah
I like the looks of those pistons:thumb:
What gasket are you going to run? gonna play it safe with C's? Or squeeze some more out of it with A's?:D
Gotta check protrusion first , and see what the pistons come in at with the CC test to see which way if any we need to cheat .
RickDLance
1,276
14
You may end up having to trim the top of one or two to get all the protrusions close to the same. I had to on my last build.
Also have you thought about CC'ing the "cup" of each piston? I think it would be pretty important to attempt to keep the volume of each as close to the same as possible.
TrentNell
Jul 7, 2008
7,543
slc tuah
I had planned on checking all the bowls and go from there if we have to even any up . and I guess we will see how the protrusion check goes , if we need to shave a few its not a big deal .
Compared to what stock?
Nice lookin build BTW Trent :thumb:
I will measure one but there are pics in this thread of the pistons before i cut them .
wdino73
735
55
Versailles, Ky
I had to fly cut 6 of mine, I set mine .012 out of the hole, I just cut the lip off my, I was trying to keep a daily driver application, I really enjoyed doing that stuff,
calabria69
Beerstud1
Oct 8, 2008
375
Santaquin, Utah
so what do you do after you cut the pistons?? are they dipped for more heat control or is this all you do?? nice thread trent, keep up the good work:thumb:
TrentNell
Jul 7, 2008
7,543
slc tuah
All the bearings looked great , as did the crank itself . I will see if i saved them and take some pics maybe this weekend .
