Don't have the answer to that one Ben but all the small things are what make the differences. I know one racer, and he is big time, that doesn't believe in the small things when assembling. Needless to say they break a lot and didn't make it to the finals and they have been champions for mulitiple years. I guess his philosophy is that they will pull it apart enough in between that the small things don't matter. Good luck with the build Trent. Hopefully it will prove useful to a lot of us in the future.
Ya i dont know Shane,The last thing I want is to get into a pissing match about what is nec. I am just going to run the motor for a while with what i have planned and see what happens , I would like to see some signs of my own on certain issue's instead of just throwing the kitchen sink at it because i am scared . I have alot of plans for the next motor , including forged pistons , Girdle/main studs , o-ringed heads ( if i find its needed ) , maybe aftermarket crank , stroker , who knows . In a sence i am starting my own motor program and will see what happens . This motor is going to be decent just a low buck build , and as long as my rods dont get taken out i would not be out much if it failed . I have seen some motors fail even after having the kitchen sink thrown at them so i want to start from scratch .
My build
all new main and rod bearings clearence set to .004 ( I think... i wrote the spec down )
cut cam and crank with key ways (done by me )
cut pistons - (15:1 compression with a custom home cut job removing all material out of the bowl to get a low compression and keep a tighter "quench" and a radiused lip )
Howard Xbeam rods
I am re-using piston rings
ARP head studs
So Cal billet injector hold downs
DPR valve springs , titanium retainers
