I'm 90% sure the no first gear lockup is not possible due to hydraulics of the trans not just electrical trickery so I don't think braydens controller can do the first gear lockup deal-e-o. There's a thread on here about this in the trans talk section.
If he's gonna to through trouble of hangin an xcase, he might as well hang a front axle also and use that second output for something.
It's too bad it's not able to be dedicated to pulling and not need roadability. Be good to see it with gearing to hit 2nd and lockup. But with 35s that's gonna need to be a loooow gear out back to do that and keep and keep a sizable turbo lit.
Cya
Time for a 1 piece.
Nice demo job Brother . Sucks , but sign of the power
You know your laying it down when your breaking chit like that .
I just replaced my short driveshaft on mine . Had serious vibration .
Twisted the tube on mine from transfer case to trans .
1/4 inch out of alignment on the u joints lining up end to end after AV Lancaster pulls
Had tube cut out and double tubed and rebalanced . All better and vibration gone .
Wheres the vid of it snapping like that .... should be a good vid if somebody got it for you .
Good thing they didn't load the sled up huh Johnny?:rofl: That would have been a failure in front of hundreds of people otherwise!!
If installed with u joint not in alignment at slip end to end all hell will break loose .
Did you have any vibrations before this failure occured
