Malibu's 2wd Sled pulling progress
2wd_Sled_Puller
Heavy Equiment mechanic
Feb 19, 2008
1,356
Florida
fixed it for you ;)
bunker hill yeah there wasnt to many stock trubo trucks there... me beating a 1/2 ass setup 2.6 is going to be hard... forget a well setup 2.6 turck when im a stock trubo..
fingers:
those 375s 33" or 35"
Hitch... i have bent this one once already... not shure i want to do it again..... extending it out would def do it more easily
butler video( off throttle no spooling)
bunker hill i left at 2200-2300rpm ~10-12psi ( i spooled there)
clarion (no spooling completly off throttle) about 1900rpm is when the sled/tires started moving and ~4-5psi of boost... i didnt stand on the brake... thats when the sled started moving.
and kurts iirc your truck was shorter then mine as in wasnt a CCLB
O ya Thats right i forgot. But i seen some where. That u where trying to keep egt's in check. And u didnt have a lift pump. A lift pump will help you out a little
624
pull 266' win was 314 placef 18 of 38 trucks.
spun the rims in the tires right was 2" and the left was 5".. tire were set @ 34-35
G80 unlocked the last 5-10 feet kinda killed the run.. tires did spin but not much..
there video should be posted later or monday..
hers the pics of the tires... white marks were inline with the vlv stem.... first one is the left second one is the right
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
Good job.
Still in 1st...or are you skipping first and using 2nd?
What's up with the rear unlocking...hope it's not hurt...!
WanaDmaxsub
Feb 17, 2007
644
I could be wrong....but I still think you need to put it in 2nd.
I'll bet your TC is not happy since it doesn't lock in 1st!
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
problem wiht 2nd is i dot turn enough rpm to hit the 1-2 shift point as is...
if i was hittign 3500+ in 1st i would go to 2nd noproblem...
4:56 will get you in second!;)
Can you weld a rear with a G80? I thought you could only weld an open diff? My red GMC I have now was a rare open diff so it got lincoln locked right away.:D
624
yeah they could then i would be bussing about 2300 @70mph with 35" tires
theres a will theres a way right?:rofl:
yeah truck has a G80 rpo code... going to look at this weekend.. change the fluid as well.
possibly weld the side gears to the pinon gears on the cross bolt.
gears
4,56*3.1=14.13
4.56*1.8=8.2
4.10*3.1=12.71
4.10*1.8=7.38
3.73*3.1=11.56
WanaDmaxsub
Feb 17, 2007
644
1-2 shift at 100% of tps, with T/H on, is at 809 output shaft rpm. If I figured it right (and I may not have...) that means it should shift at 2500 motor rpm. 1st gear is 3.10:1
624
1-2 is @3200rpm i am rarely above 3000..
if i do manage to hit 2 and the t/c locks i will pull me below 2000rpm/ uner the turbo
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
If it where me I would look into hanging a T case for lowrange. That way you would have more gear options and you would also save your trans from 1st gear burn down. What worries me about going for second high is if the the TC locks your output shaft will hate you for it.
