Malibu's 2wd Sled pulling progress
624
Adam have you regeared or still 3.73's? What gear do you pull in?
currently 3.73 with 315/75 out back and first gear. 2nd if 58% longer then 1st
1st is 3.1
2nd is 1.8
IMO i dont have the power to run 2nd right now especialy if the TCC locks as well
i dont have a transfer case so there is no 2.72:1 reduction that the 4wd beniefit from.
624
been hooking to the sled lately...
stated in london 3 weeks ago
got 23 of 26 trucks with a 22" hitch for 181.x win was 269.x
wilmintion got a 25" hitch went 259.x pull offs were @ 310' dont know what i place but def mid pack bent the hitch
picture fo said pull
made a hitch
attachment.php
last night 6-26-09 ran down to the circlevill pull went 296.x for 13 or 24 truck win was 337'
also droped then t/b all the way and put the spare donout 245s (30") tires on the front with 35" out back
and did this to my hitch.. felt the front bottom out couple times at full droop and it bounce coupel times as well.
attachment.php
all these pulls are against 2.6 trucks
OSUDURAMAX's fiance(sp) took video of my last pull should have it up soon
still need blocks
SmokeShow
6,818
Lawrenceburg, KY
yeah, you have GOT to get that rear end up in the air higher so you aren't putting so much leverage on your hitches. It'd take something stupid strong to not bend with as high up the "L" as you are having to run it.
624
Hey Adam way to go with the 2 wheeler. Its been a while are all your mods in your sig?
.040 over block, crower rods, stock fuel and air.
Is that solid steel?
yes solid 2"
bend it straight double up with another 2" makeing a welded 2x4" piece.. and wear face the front side with and stick weld.
getting some 2" blocks for the rear.
might get some 26" tires for the front drop it another 2" form the 30"
and blocks
624
never mine the rear bumper... damn jumping telephones poles i tell you what
mitch.. i have been thinking the same thing but not to that extreme. the ~1300lb of balast i put in the bed squats the truck ~2.5" at the rear axle. measured at the frame to axle bump stops.
2.5" of travel at the axle center point is 3" at the bumper.
might go 2-3" above ride hieght(empty) due to u-joint angles/current springs. since COPTC is allowing solid rear suspension.
depending on how high the hitch point is might run strap/brace form the top of the verticle point to the frame. seeign some classes require X" of travel
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
:grd:
Air bags to get your butt up in the air.
2nd gear! You have enough!
Good job!
Sorry I didn't call you back....found a place that doesn't have cell service:D
624
:grd:
Good job!
thanks... here soem things i did over the weekend.
pulled as well went 259' in some slimmy sticky clay with bald tires... placed 15th out of 24 truck 2.6 class
im goign to see if i can borrow a set of MT claws there is a pull 9th up in butler county fair by FPP....
624
pulled again tonight went low 200 2" suspension travel :( and 30" hitch...
didnt think i would be pulling on a sand track in western PA :rolleyes: oh well... do need tires...these are about shot.
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
You had a good pull IMHO. That track is tricky. It could have been much worse. You could have pulled with me and BDL.;) Any night you go home in one peice is a good night. :D
