Lowering and Tires
1slomax
Dec 6, 2011
260
Harrisonburg VA
Throw some pics up when you get it lowered.
I got a quick question for you since you had a lowered LBZ. On mine the rear end feels like there is only about an inch of shock travel then it feels it bottoms out on a steel pipe. It doesn't feel very good when you have passangers in the bed, they get kinda mad. Any ideas?
did you remove the factory bumpstops
flyinelvis11
543
50
VG, IL (because my wife does)
Finally got mine done. 3 inch shackles with the torsion bars all the way down,305/50-20 tires
picture.php
picture.php
mmm...i love those incubus recoils! i did 2" djm shackles but i've been rocking the pyo's since i've been trying to improve my track times. i am looking forward to seeing what my truck looks like with the rear dropped and my recoils back on
13,736
806
None so far... I also have air bags though
Sledheadxp800r
That was only my tow tune
Dec 13, 2010
1,151
CT
Do you guys run standard airbags with 2-3" drop shackles or are there ones designed to work with the shackles?
13,736
806
There isn't really enough room to fit the airbag between the frame and axle on a lowered truck like there is on a stock height truck. If you do it, the bag will bottom out and cause a very harsh ride. You need to move the bag either inside the frame on some custom mounts or use the sport-ride kit that uses a smaller diameter bag and mounts on top of the spring outside of the frame between the frame and tire. You may be able to mount a full size bag on top of the spring if you install a wheel spacer on the back and/or have a big offset wheel that pushes the tire way out.
Sledheadxp800r
Dec 13, 2010
1,151
CT
These look like they could work. I wonder if they will get in the way of my gooseneck though
07bluelbz
Work Hard & Play Harder
Sep 6, 2009
742
Beaumont,Texas
Thanks i need to get some caddy handles like yours. Do they come in our color or do you have to buy some and have them paint matched?
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I'm thinking about doing some 3" drop shackles and I need shocks now too. What do you guys recomend for shocks? stock length or shorter? what type?
