Lowering and Tires
Trotorx2
699
71
Beaumont, Texas
RANCHO RS999262 seem to work well 23.87 length, stock is 26.25
I have 2" drop schackles with stock size yellow Bilsteins and they ride like crap. I decided to get some Rancho 9000's and I sent an e-mail to rancho asking for a part number for a lowered shock but they took forever to answer. I got tired of waiting and ordered the stock height shocks. I haven't installed them yet so will they ride like crap too? I was going to set them on a low setting since I'm empty most of the time.
slipclutchms
427
airlift 57215 mount on the outside of the frame.....I think they are intended for ford use but I made a set work. I bought them from summit.
Duramax5
duramax freak
Sep 15, 2011
417
West Texas
Thanks i need to get some caddy handles like yours. Do they come in our color or do you have to buy some and have them paint matched?
no u can get em already painted, atleast u could 2 years ago. I bought em from the Chevy dealer. Even came with the tailgate handle. That one is all blue tho
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Josh that pic is how the ford bags mount since their frame is more narrow than ours as well as not as tall. You will need one hell of an offset or big lift to clear those bags, I tried this a few years ago when I was starting to lower my lBZ and only the smaller 1500 bags seemed to work as they are a single bag but will only carry about 2000 lbs.
Ryan T
1,007
CA
It may ride ok but u are only going to have about 2 or 3 inch of shock travel,u would be better off sending them back and buying shorter 1s
mb1
149
Edmonton, Alberta
I thought I had read that stock length shocks wouldn't bottom unless you notched the frame for some serious drop.
I removed my OL springs, truck rides great. Just put my airbags back in and now the back end bounces around. I still need to lower the air from 15# and see if that helps but I think the bags are limiting travel like someone else said. I'll have to see if there's room to mount the bags inside the frame.
I was also going to plumb in a small reservoir with each bag to make the support more linear as load increases. I think it would help ride quality by reducing bouncing.
13,714
776
I didn't know that. All the one's I've dealt with on the Fords are the new style that mount inside the frame.
slipclutchms
427
This is how mine came out.....the u bolts in the kit are for 3" wide leafs do I machined some spacers to keep them centered on the leaf....I'll get some better pics up. Definitely need some offset wheel combo. I'm running 2" spacers anyways so it should clear
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Well, started on the GMC lowering it. FWIW stock height silver bilsteins will not work with a 3" drop shackle and no overload. The rear end of my truck is currently sitting on the drivers shock fully collapsed; passenger side still has about 4-5" of stroke left. Need to order those rancho's next week.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Will do. I still have to pull the bed off after it's running, put on DJM drop hangers and lower control arms. Cant do much more with it sitting on jackstands :eek: :rofl:
07bluelbz
Work Hard & Play Harder
Sep 6, 2009
742
Beaumont,Texas
I have a question for all the lowered crowd. I bought the II Crave wheels on my truck used and don't know the offset but The tires are rubbing slightly on the fender behind the tire. Anyone else having this problem or is it due to the off set? I can bend the metal back some for clearance but I hate having to do stuff like that on this truck.
