lowered truck pics
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
The center line of the engine/transmission and differential pinion are parallel, just remove the front prop shaft for the single drive line.
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
I got a single piece shaft on the reg cab, 3 inch shackles. Pinion angle isnt perfect but dropping the overload helps because is Slightly raises the rear end up. And having the longer single piece shaft helps a bit to.
6,117
1-2* isn't the end of the world. You get beyond that and things start vibrating and causing you issues.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
If you do get a vibration after installing shackles check the transmission mount, overtime they can sag quite a bit. IMHO I think it may be a lot vibration problems as it knocks the centerline parallel off.
motoking_1990
1,957
5
Terre Haute, IN
Finished lowering today. I'm so glad I decided to lower it. Looks way better than before. I know most of you don't care for extreme offset wheels but I think it sets it off.
minerigger
2,660
Casper, WY
Did you go from leveling keys and blocks to stock keys with bolts backed out and blocks re over with 3" shackles? Like the stance...alot
motoking_1990
1,957
5
Terre Haute, IN
I went from factory blocks in the back and leveling keys to no blocks and 3 inch drop shackles in the back and 2 inch drop keys in the front. The back sits 5/8 of an inch higher than the front.
TMAN
95
29
No more chrome trim and a quick clean up. Still not sure if I want to go lower yet or not
minerigger
2,660
Casper, WY
Looks very good. Well put together. What are you running for shock now and are you going to change them
motoking_1990
1,957
5
Terre Haute, IN
Thank you. I have spent a lot of time making it look the way i want. Anything I wasn't sure about I just replaced. Like all the hardware for the rear springs. When I changed the springs I could've used the old bolts, u bolts etc. I just bought new. It's really the fine details that set it off.
Believe it or not I'm almost positive they are the factory shocks. None of them are blown yet but I been looking at some blisteins. It's up in the air right now.
minerigger
2,660
Casper, WY
I can tell you I've got 5100s for stock - leveled and they are nice for that but with 2" shackles it's a little stiff
