Well so far 1,3,5,7 have their tips and mechanical everything is good going to run lash again. Since im there and its a pita to get toDang Adam, that sucks big time. Hopefully it is just a hung injector, and it is easy to swap out.
I think if it weren't for bad luck, you'd have no luck at all
glass half empty, atleast it didnt happen on a run
You must click Activate and Enable Master Fuel Injector Control
Sounds and looks like a broken injector seal
Seal=tip?
You really need to kill cylinders and find the bad one. I'm thinking one injector got dirt into it and is now hanging. It takes about 5 minutes with a scanner.
Sounds like #1 might be your culprit. If the injector is hung open or leaking, you could try pulling the glow plugs and cranking it over without the injectors plugged in, and see if one (or more) cylinders spits fuel out the glow plug hole. Not familiar with the newer engines, but you might be able to just unplug the bale connectors to disable the injectors, but have it still crank.At time of the vid i had no control.
Some reason it decided to give me control after I stopped the video. And smoke went from white to black.
https://youtu.be/PTQFanFDMaE
Starting with glow plugs it stalls on a cylinder.
Black smoke comes and goes in relation to #1 being on/of
Still not as smooth as it should be. First time in 332,000 miles ive had injector issues of any type.
I've got means of jumping the starter lolSounds like #1 might be your culprit. If the injector is hung open or leaking, you could try pulling the glow plugs and cranking it over without the injectors plugged in, and see if one (or more) cylinders spits fuel out the glow plug hole. Not familiar with the newer engines, but you might be able to just unplug the bale connectors to disable the injectors, but have it still crank.
