LMM: LMM with 222,000 tear down rebuild
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Cool deal
Now go and make some money!!! I'm by far not the smartest guy but there isn't much I haven't tried and run into at the shop. I seem to get everyone else's problem. lol
611
Now im fighting couple inj linea that dont want to seal
Definitely noticed a difference 15-2100 rpms everything is more responsive.
One example is turbo would do 2psi boost at 2200rpm at 0% throttle
Currently it will do 2psi at 1700 rpm 0% throttle
611
Little load.. might find something to go with it..
Its definitely got a louder exhaust note
3,729
297
Glad your back on the road! Definitely keep us posted on how the cam treats you.
It is interesting that you see boost sooner with no throttle input with this cam, yet peak boost is down. When I put Wagler heads on my truck, it dropped boost across the board. Used to do 3 PSI at 65 MPH cruise, now does 0 PSI, but still pulls the same when I get on the throttle.
Sent from my FlashScan V2
611
Cruise boost is same range with the empty trailer 5-10psi
Seams to be using less throttle to do it..
While i haven't seen or profiled this camshaft, ive been "told" it has 5-6° less valve over lap than stock. Which would reduce backflow/egr effect on the cylinder..Combined with the T3 .83 A/R housing doesnt really surprise me.
Got a full weight load (20,000lbs on deck, 36,000 gross) of couple skids and concrete form work heading from Columbus ohio to Winston Salem area NC
Like to know how much valve over lap is on it lesa would definitely be helpful for the DD/under 3500rpm guys
Digmax
289
Any change in your tuning? Also what is exhaust temp in comparison?
Sent from my C811 4G using Tapatalk
611
Only thing ive changed so far pull pilot timing to 600uS across the table.. was running 900-1500uS in OEM seting in the cruise area
As for temps... Nothing noticeable. Load weighed 4700lbs got shuttled 65 miles to the yard.
Oil temp is up ~10° then again more of the combustion cycle is staying in the cylinder vs going into crank case
Idk if the truck is making more than 400hp definitely has a better application of power though
Theres alot of hills on this route.. and i will be low and heavy..
611
Is that where the Simpson's live?
Nope
But here is some americana...
http://www.dailymail.co.uk/news/art...ringfield-revealed-creator-Matt-Groening.html
According to the U.S. Geological Survey, there are 38 places in the U.S. bearing the name of Springfield, of which 13 are cities and 11 are towns. Wisconsin leads the pack with five Springfields, followed by New Jersey and Texas.
Springfield, Alabama
Springfield, Arkansas
Springfield, California
Springfield, Colorado
Springfield, Florida
Springfield, Georgia
Springfield, Idaho
Springfield, Illinois, the state capital of Illinois
Springfield, Indiana
Springfield, Kentucky
Springfield, Louisiana
Springfield, Maine
Springfield, Massachusetts, the first Springfield settled in America
Springfield, Michigan
Springfield, Minnesota
Springfield, Missouri, which is the most populous Springfield in America
Springfield, Nebraska
Springfield, New Hampshire
Springfield, New Jersey (two)
Springfield, New York
Springfield, Ohio
Springfield, Oregon
Springfield, Pennsylvania
Springfield, South Carolina
Springfield, South Dakota
Springfield, Tennessee
Springfield, Texas (two)
Springfield, Vermont
Springfield, Virginia
Springfield, West Virginia
Springfield, Wisconsin (five)
