LMM: LMM with 222,000 tear down rebuild
turbostang7
Apr 11, 2011
239
Rexburg Id.
The silver lining is you will be great at a duramax rebuild at the end of it all!
All joking aside I would have pushed the truck off of a cliff long ago lol
624
The LBZ block currently has no cracks looks good bearings a hammered at best.. Guess that's to be expected
The LBZ RA is little rusty mainly surface area that aren't wear areas..
bmc1025
521
Big Bone, KY
BES Racing Engines is out of Indiana. His facility is amazing, super clean and he is quick to get back with you. He builds most of the engines at gravelrama and has a deck plate for Duramax blocks.
He keyed and polished my crank and cam including taking the gear off the crank and keying under it. Resurfaced my heads and properly sunk the valves to match.
http://www.besracing.com
624
Cant wait to see that bill...
1600.00 for
Deck
Bore
Check balance of RA
Check block/crank for cracks and pressure test block
Couple hot tanks
Brought in a disassembled short block
Told the Greg the main main machinist about the block.. Got the "yep seen that" comment.. When mentioned lost a crank but no visible damage to block so machine block put it back together then block breaks...
Mitch, Brian amoung others been riding my ass about jumping to Cummins or big truck.. Which have their own issues
