Nortech 392
And yes, we run offshore for yellowfin, mahi, white marlin, and usually stop in at the shelf for deep dropping for grouper.
Very Nice
Nortech 392
Not a job bro! Only do this for fun.
you must get payed to have fun then lol.
Rick lance's pipes before being converted to wet manifolds
Still in the shop, they'll never look this good again
So I'm assuming you're wrapping them with sheet metal?
600ish?? I think.
You might want to consider calling SOCAL, and see if he can do a custom cam for you. Do some port work on the heads, and move your power band up. That way you can limit your bottom end torque(where rods tend to get shortened), and still get your HP goals up top where you need it.
The 500hp range should work just fine for you.
When myself and a buddy were looking at doing the repower we figured on 2200-2400 rpm range at cruising. Once plane'd out the hp/tq required should drop down quite a bit but getting it to that point is where it will work the hardest at higher rpm right? Kind of like towing a big trailer from a dead stop to highway speed. All depends how fast you can get it to pop out of the water. Our biggest concern was how to keep the oil cool. I would suggest installing an oil temp gauge to monitor it.
I'm hoping 450-500 will get me up on top and still be on the upside of the torque curve when the boost comes off. I don't think you can utilize big hp like you can with gas because of rpm limitations, at some point you run out of prop.
Innovation settled with 550 hp and burned a few pistons getting the tune right. As you know a boat is more like a constant uphill tow
Another local long range rig.
Midnight Express hull, scarab top cap, pursuit console, total mutt boat running 440 yanmars detuned to 380hp ( to keep to bravo xr's alive). Cruises around 45-50 and gets 4 mpg.
