Lift pump?
Diesel Pilot
Hat? Suitcase? 50 BMG?
Aug 9, 2006
1,424
47
Pickerington, OH
To me the 1792/PPE pump is slightly annoying only when the truck is at idle. I have to turn the truck off when going through a rive through anyway so it's not that big of a deal.
I've never noticed the pump when I've been driving.
9,905
151
Running your pump off of a fuse is a bad idea. Painless sells a fuel pump relay kit pretty cheap. It can prevent un-wanted smoke;)
I agree. A simple Bosch relay is normally what I use. Relay's are definetly a better way to power a pump, and can be switched off of the switched power in the fuse box. But, either way, if something goes south, you won't cause anymore unwanted smoke with or without the relay, the fuse will still let go and power will be discontinued. Providing the fuse isn't good for 50A :D That's why I went with the ABS fuse-it's only 10A. And on the power out terminal, not the power in one.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Dunno. When I first tried the 1792, I was told it would not deal with diesel fuel, but the same pump is working over 2 years later.
I tried the Mallory (worked, but not high enough flow) and the Holley HP150 (great flow, busted in 1 month) also, as well as the "old faithful" Carter pump.
Cobra#3747
Jan 2, 2007
119
Baltimore, Maryland
I had good luck with the 1792, till it got cold here. 2 warranty pumps, both started leaking within 24 hours of install. I figure it must be the seals shrinking in the cold or something. All 3 leaked fuel from the wire pass through.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
I wonder if that is the seal Dan said they upgraded when they had the PPE pumps made?
Cobra#3747
Jan 2, 2007
119
Baltimore, Maryland
He told me it was all different seals and different impeller.
There is a shaft seal that is at the base of the motor, where it goes into the lower block. Thats the one that is allowing fuel into the motor and filling it up till it runs out the wire pass through.
The last pump, I took it apart, drilled out the outlet and reduced the fuel pressure to 7.5 psi at idle in attempt to relieve some of the pressure off the seal, still leaked in 24 hours.
paint94979
Beer Nazi
Sep 18, 2006
11,715
Try PPE's pump it works great.
9,905
151
You know Pat, that same cheap noisey POS Carter pump has probably pumped 10 000 liters of fuel out of my slip tank into my truck fuel tank and it still works great. I have taken it apart and cleaned the screen probably 5 times, but it's still going strong. I wonder why.....
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
It stranded me twice with the kids in the truck once at 10 pm at night in the middle of the street :eek: Never again will we put a Carter on the truck I drive.
Diesel Pilot
Aug 9, 2006
1,424
47
Pickerington, OH
You know my 1792 was going great until it got cold here, as well.
Maybe, I'll just use the pump as a summer time thing. I don't need crazy power when there are 15" of snow on the ground.:D
LB7Diesel
Oh Boy!
Sep 3, 2006
1,355
Melbourne, F.L.
Probably why mine is still working so good. It doesn't get to cold down here in FLA. Most of the time it is" Flippy" weather:D
For everyones info. All the seals in the 1792 pump can be purchased at your local Hydrolic repair shop.
