Send me that Hobbs switch, I'll use it for something else...
ha, the Hobb's switch is still connected just like you set it up. for whatever reason I just never hooked the other wire back up...
Just installed the AIRDOG 150 W/ tank pick-up last week. The only time you can hear the pump is before you start the truck, It keeps up with all the fuel my ppe hot+2 et asks for. I would definetly recomend this kit.
My air dog should be in by weeks end, any install tips to pass on?
I could be wrong, but I think the fuel demand rate is actually based on RPM not pulse-width (pulse width goes up with boost).
Our CP3 is based on return. The regulator allows fuel into the high pressure side, but if there is no demand, it still is pumped, it just goes into the tank instead. Injectors return fuel every time they release, regardless of the duration of the shot.
I've never measured return yet, but that's how I thought it operated.
Why is there two avater pics in my responses?? If some one can tell me how to remove one of them or can get rid of the lower one I would appreciate it.
I fixed it You had it set up for a avatar pic and a sig pic. I removed the sig pic.
ill be getting a PPE pump soon and not sure what fuse to hook it to i know i want it on the ignition fuse but not sure what fuse to use.
Jared
Drop the tank its alot easier then pulling your bed like others have done, took me all of 15 minutes to drop my tank and about 20min to put it back in with a extra set of hands. Are you going to use the tank pick-up? If so make sure you have a shop vac going when you drill your tank, to keep any shavings from going in, You will have to cut the fuel pickup to length. Be sure to support the bottom of the tank with some 2 by 4's or something comparible, placed were the straps would normally support it this will assure you get the right height to cut the pick-up down to. You also need to cut cross hatches in the bottom of the pick-up. Check and double check that you have all the fittings, some people have been missing a fitting or two and needless to say they did not relize untill they had there trucks apart. I have a bunch of pics if you need them. Also I fabricated a different mount for mine so the filters would sit a couple inches above the frame rails and also run parallel to the frame.
Thanks for the heads up much appreciated. Not sure about the pick up, I know of one running with out it with no problems though its an lmm.
