Lets discuss Injectors, big fuel
skintback
Take this one to church
Mar 5, 2007
919
Florida
I cranked #8 piston while gassing it a little driving down the highway
I bought the truck brand new and had a tuner in it before i left the dealerships lot from there it was about more power and go faster :)
2005 CCSB 4x4 running EFI live
injectors stock
PW 3000
timing 32*
1 LBZ pump with modded reg
stock turbo
stock motor with head studs
Air dog 150
fishsmith
1,402
42
Monroe, LA
I cracked #6 running down the road at about 75mph. Although I had pulled my 5th wheel hard the day before. I was running Dmaxtuner tune. I think I got mine the day before and just finished it off the next morning. I had started playing with w/m, but I ran straight water in it while pulling. All stock injectors, turbo, cp3.
calabria69
Beerstud1
Oct 8, 2008
375
Santaquin, Utah
so with more air flow, is there a more specific amount of timing and PW??? can you use a little less timing and more PW?? just in the learning stages, this is a great thread.....
05smoker
I'm officially done!
Mar 30, 2007
2,379
Lebanon, OH
How much rpms are people turning when they hurt pistons?
I have heard of several cases where they were cruising along at lower RPMs (2k-ish) but it was shortly after they were running it hard or racing it.
I'm more of a fan of high timing than too low. I think a lot of PW and low timing (high smoke and high egts) are worse than most full on race tunes. Just my opinion, not any data or fact. I think Pat has mentioned somewhere before that he saw some break at 20 degrees timing before we had the ability to raise it higher.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Motor #1 (factory)
What happened- 2 pistons cracked all the way through, big cracks starting on 3 others
How many miles at this level- 85,000, abused daily
#1- Injectors- STOCK
#2- PW- 3200
#3- Timing- 27*
#4- Fueling-SINGLE UNMOLESTED CP3
#5- Turbo - couple different ones, BD, HTT, stock
#6- Motor built or not- NOT
#7- LIft Pumps - twin kennedy's
Motor #2
What happened- 2 broken rods, the rest of them were all bent Bearings, pistons, and everything else looked flawless.
How many miles at this level- 16,000 miles, abused daily, because you should be able to abuse a built motor without worries, duh.
#2- PW- 3300
#3- Timing- 29*
#5- Turbo - MPI twins
#6- Motor built or not- YES!!!
Current engine:
Runs perfectly, has almost 18,000 miles on it.
#1- Injectors- Big Dipper
#2- PW- whatever stock LLY is, 1400? I forget
#3- Timing- stock LLY, 11*??
#4- Fueling- stock LBZ CP3; 26,000 PSI
#6- Motor built or not- stock LBZ short block, LLY heads, head studs, keyed cam
ben
[email protected]
cmitchell17
Sep 8, 2008
251
I don't know a lot at all, but airmass (grams per cyl.) drops off a lot as rpms rise, but airflow increases. Since airmass decreases if you fuel the same you will have a lot more fuel than air.
In my tune I cut back fueling a lot to keep the air fuel ratio consistent. When I cut back fuel (pulsewidth) it also cuts back timing that is required for that pulsewidth. This is at higher rpms where it looks like problems with fuel spraying to early and too late are complicated with rpms.
I havent noticed any loss becuase of cutting back fuel at high rpms either.
Huntinducks82
Apr 21, 2008
422
42
Centerville MD
What are some problems guys are havin after injectors. I have read this thread and others and have not seen any down side to runnin them. I plan on buildin my truck into a 2.8 pullin truck this winter and would like to hear about problems that come with injectors as i plan on gettin a set from BIG DIPPER.
steakman
Diesel Nut...
Aug 31, 2009
69
Barrie, Ontario
Motor #1 (factory)
Nothings happened...YET.!
me - 143,000..treated nicley - it makes me $$$
Same
#2- PW- 3200
Stock..??? How does one measure that.?
#3- Timing- 27*
Stock..?? Also - how to measure.?
Same - Stock
Stock
Same - stock Engine
None - About to order an Airdog100
So, basically I know nadda bout the engine itself..at least to the depth discussed here. (facinating to be sure). Question for you guys:
I run a Banks 6 Gun pda set up. It was suggested to me for mild tuning/no wild fuelling & combined it with a Transgo Jr in the Ally. I'm about longetivity not racing. Not in the abuse club..wihich is not to say it doesn't get worked...it does, from time to time by pullin my travel trailer.
Typically I run it (banks), at level 2 and the very odd time will go up to level 4/5..not often though. So, do I need to worry about internals (pistons/rods), at this time.??:confused:
Fluids - Filters et all, get done on a regular basis.
Thank you. Super thread..!:D
ZeroGravity58
1,401
51
Maryland
How many miles at this level : 10,000
#1- Injectors: Big Dipper 25%
#2- PW: 2500
#3- Timing: 21* at 3000 RPM, 27* at 3800 RPM
#4- Fueling: stock LB7 with LBZ reg
#5- Turbo: 4094
#6- Motor built or not: Not
#7- LIft Pumps: Kennedy twin pumps
By going with injectors i cut 7* of timing off at 3800 RPM's and dropped my PW by 650. i also picked up 3 tenths and 3 MPH at the track....IM not a big fan of big PW. i only ran a few thousand miles with a 3000+ PW before putting in injectors.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
How much can PW be reduced by using 100% injectors ? I've noticed these coming up where as I used to see only 40% / 60% .
Drholliday
286
Gresham, OR
I was talking to Dustin About this yesterday b/c he is running the 100% overs, and its what I'm planning on running. The topic came up about stock power levels with the 100 overs. He guestimated that it would be well under 1000 pw for a stock powered tune, possibly as low as 500. And if you think the stock tunes are around 1400 max pw IIRC. Thats a pretty big reduction.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Steak
Im biased but i wont run a canned tune,Most of us on this site run custom tunes via EFI:) We have the ability to know how badly we are destoying are motors:D with the logging capabilities. It will tell us the timng and mm3 and duration of the fuel shot( for the most part).
Your Banks is a different story all together because it fools the factory sensors....Not many people blow motors with a Banks tuner.....They also dont realize the potential of these trucks though;)
IMO and i run tunes in cold weather......you need to adjust for the ECT and IAT....not many tunes do this:( This is one of the many things EFI live does.
Lot of people think EFI is for the power junkie,But its really for anyone that wants to CUSTOM tune ther trruck to it BEST potential:)
steakman
Diesel Nut...
Aug 31, 2009
69
Barrie, Ontario
Thanx Sweet.
I understand timing being degrees before TDC and ATDC. mm cubed being actual amount of fuel going in...and at what point in the stroke. I would love a clear explanation of Pulse Width - at least in relation to these engines. is that infact (above), what it is.?
I see guys commenting on 3000, 2000 etc. ..am guessing that is in milliseconds and the total elapsed time of the fuel shot. My reading leans me to believe that this amount of time is reduced with larger injectors due to larger amounts of fuel going in over a shorter time period. 100% over - 60% etc. over are percentages of size increase over and above stock injectors.
So it seems there is far more room to play as far as the actual time one injects fuel: Using a said amount of fuel with larger injectors as opposed to adjusting fuel amounts with a stock injector..right.?
is gonna take some time to figure...hope Im on the right track of understanding.
Theo
ZeroGravity58
1,401
51
Maryland
Thanx Sweet.
Theo
You are right. When running a stock injector with a high pulsewidth you are chasing the piston back down the bore with fuel. By running a bigger injector you can inject the fuel faster with a smaller pulsewidth and at a more optimal time. Some people will say injectors are worth it, some will say they are not. Personally i think they are worth it and my time slips say they were :D
Alligator
Nov 9, 2006
1,919
N. Idaho
Mine happened at idle right after start up. Brother was driving it pretty hard during the day I suppose, rolled into the parking lot, shut it right off w/o cool down. I get in 4 hours later, and chugging white smoke out of the tailpipe, and shaking the whole truck.
steakman
Diesel Nut...
Aug 31, 2009
69
Barrie, Ontario
aahhhhh..! the fog clears somewhat...! so to find said optimal time, one must use EFI .. experiment too of course. very interesting. I can see how applying this knowledge would be extremely beneficial in making a tune that would provide optimum mpg's. If that is true, then I thinks I am gonna end up eating some of my previous comments (on DP) re: mpg's on lbz's. to a certain point anyway.
I am sure that there is a lot more to writing a tune than just pw/injector size and amount of fuel etc. But I disgress. I have no holed pistons that I know of, nor bent rods that I know of...so back to topic. The defence rests :)
Theo
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Here is a picture of a cracked piston it only lasted 370 xxx miles with high timing And improper fueling via me.:D
