SikDmax running 500hp on stock turbo stock sticks McRat tuning - pop.
Simons buddies LMM above similar story - pop.
Henrys was stock motor 4094 turbo I beleive - pop.
Chad Alligator was stock- pop.
Tommy had dual fuelers, cheetah but pop.
Motohed stock stock pop.
Who else? Theres tons more. Several different tuners and styles of tuning.
Lb7 and LLY's don't have the piston problems of the LBZ/LMM
Sure they do, just not as many
Right...........
That must be why they are used in built motors
How many miles at this level-
25000 miles at 640hp
#1- Injectors- stock
#2- PW- 3000
#3- Timing- never went over 30
#4- Fueling- stock CP3
#5- Turbo stock
#6- Motor built or not- stock
#7- LIft Pumps Airdog 150
How many miles at this level- 80 000 LLY
#2- PW- 3300 depends what day highest was 4000 untill raw fuel shot out exhaust
#3- Timing- 32 depends what hour of the day
#4- Fueling- 2xcp3s for 5k ish
#5- Turbo HTT for around 5k
#6- Motor built or not-not
#7- LIft Pumps KDs
Truck ran 100s of different tunes and shared a lot of these with Larry
truck died after towing 1000 miles on a 2200 pw tow tune the next day i switched back to the race tune and pop it was running very good before it died
Can we add broken cranks to this too?
to much timing ==> high cylinder pressure ==> cracked piston
to much pwm ==> to long of a burn cycle ==> melted piston
find the middle way and you are fine ...
where is the middle? Too much to some people is not enough for others and vise versa
that why we spend hours and hours on the engine dyno to find that out ... Sometimes to late ...but i think we figured that out now.
just to open a bit your eyes ...
By 1800 bar pressure, 4000 rpm, 30 degree timing ...
You actually spray from 15 degrees btdc and 71 degree atdc in the cylinder and spray totally 86 degree In there ... That a looong time of fuel going in to the cylinder which is a lot of heat.
you are right, but sometimes conditions on a dyno arnt the same as real life street or strip driving. Do you tune them with a cylinder psi probe? There is mixed results on tuning on how to get to a desired hp # like lets say 650hp; turn pw higher, timing, rail psi. Another is higher pw low timing, higher rail psi. Put injectors in, lower pw, lower timing, higher rail psi. All these ways will give you the desired # mentioned above, so wheres the middle:d
Cracked one piston three others were on there way out
