Brayden: When did your engine blow running my tuning? That same tune has been on Blue for years with no problems, and was loaded on your truck Feb '06.
Sik had posted that... Not me I snipped it
Perhaps he should have made it more clear. I tuned his truck for free at the Suncoast open-house, and he was very happy at the time. That post looks like I blew his truck up. In any case, he copied it into this thread for reason.
Yup, I figure about 2% of the trucks I've tuned have blown up. Best guess is that I've tuned 600 trucks (probably much more). My only guarantee is that anything I sell or give out for free will reduce the life of your engine, or your money-back.
If somebody tells you big injectors will stop your engine from blowing up, they are selling injectors, not truth. What worries me, is that if they have worked on lots of trucks as they claim, they do know the truth, they just omit it.
No diesel shop has any failures, but they do love to discuss other people's failures.
This is a spin off thread.
I'm interested as to what is killing motors. Is it timing, PW, duel fuelers or large turbos.
Can we get specifics listed so to try to figure this out?
What are the specifics?
What happened hole in piston, bent rod-
How many miles at this level-
#1- Injectors- Big!
#2- PW- Less than 2000
#3- Timing-As high as 35* at 4000rpm
#4- Fueling-27000 with CP3x2
#5- Turbo GT4202
#6- Motor built or not-Built by with the same LB7 pistons that where in the engine delipped and cut by me
#7- LIft PumpsHolley HP150
#1- Injectors- stock
#2- PW- 3200
#3- Timing- 40*
#4- Fueling- single Cp3
#5- Turbo - MPI Twins
#6- Motor built or not- No
#7- LIft Pumps- Airdog 150
= Hasn't happened yet :cool2:Snipped from another thread...
So lets talk about it then.... Im sure this will get split.
Me running 500hp on stock turbo stock sticks McRat tuning - pop.
Simons buddies LMM above similar story - pop.
Henrys was stock motor stock turbo I beleive - pop.
Chad Alligator was same story - pop.
Tommy had dual fuelers but pop.
WikdLMM stock stock pop.
Not a commercial... Just stating what I've found to work. Short PW enough timing to achieve a 12-18 degree EOI and enough boost to clean it up.
What happened hole in piston, bent rod- ROD/PISTON SEPARATED AND WINDOWED THE BLOCK
How many miles at this level- 7500 OR SO MILES DAILY ABUSED. PROB 40K TOTAL WHEN IT WENT
#1- Injectors- STOCK
#2- PW- 3200
#3- Timing- 30
#4- Fueling-SINGLE UNMOLESTED CP3
#5- Turbo - CUSTOM TWINS HT60 OVER STOCK LB7
#6- Motor built or not- NOT
#7- LIft Pumps - FASS 150 (PUMP ONLY)
This was Importkilla's 03 LB7. It never saw a day where it wasn't abused. Tuning wasn't the greatest since EFI Live just recently came out then but I have looked back at it several times and have not seen anything I wouldn't try today. The motor had been bastard stacked for several thousand miles prior to twinning it. Ate a couple purple trannies along the way as well. Dynoed 589 IIRC on Dunbars.
Well hell, nobody said anything about tranny's, I'm on # 5 including the stock one that nothing was wrong with but my motor is still alive...........where some freaking wood to knock on now
WikdLMM stock stock pop.[/QUOTE/
How did my name get thrown in this? Been running 500hp tune for about 50k now an no problems(knock on wood)! Who posted my name?
I think he meant SIKLMM, not you buddy.
Dang chad some people trying to curse others?
Nah, it's easy to get to Sik LMM's mixed up, especially when they are both white.
