Below are some instructions for the LBZ DSP switch. These instructions will not be the same for LMM.
DSP2 switch is on Connector 1, pin 52
DSP5 switch is on Connector 1, pin 46
The ECM itself has the pin numbers printed on it to ensure they have the correct pin.
As a reference to make sure they are going in to the correct pins, pin 47 should have a Grey wire in it already and Pin 53 should have a Yellow/Black wire in it.
The switches themselves are done the same way as the LB7/LLY DSP, so use the details in the existing DSP tutorial as a reference (You'll find this in both the scan and tune tools under HELP>TUTORIALS or as a download on our website).
Given the switches are the same as LB7/LLY you can purchase a switch from an EFILive vendor, just check and make sure they have the new pins in stock. If they don't you can source the pins from your GM service department (not spare parts), the Pin is in Tray 19, and the Terminal part number is 1928498135.
This should be enough information to get you started.
Cheers
Cindy
Cheers
Cindy
