EFILive LBZ Switch instructions
9,903
149
Does anyone know what gauge the ecm wires are? I want to buy a multi-conductor wire to run into the cab to make things cleaner and want to get the right gauge for the pins.
Brian1
Jan 1, 2008
103
Does not take much as gauge size goes. I do not know the current DSP5 switches one can buy for LB7 or LLY use. I say 22 gauge be plenty. But maybe Cindy from EFILive might help others.
Brian
Dec 2, 2006
1,696
TN
I just bought a Radio Shack rotary switch, I wouldn't recommend this thing. It's crap.
It doesn't even come with a knob to turn it.
Also,
Will a 5 Position work, or does it have to be 6?
bushmaster
Aug 21, 2009
15
ok, so the pins you guys are talking about for these switches, you are referring to the pins on the ends of the wires on the switch that would click into the spots on the plug (crimp on the wires and insert in big plastic plug with all the wires in it) on the ECM correct?
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Here is a pic I borrowed from SoCal Diesel website. It's an LB7 but you get the idea :D
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Its a 5 position rotary switch and will have resistors to limit the current. IT will need to have the correct terminals for the LBZ/LMM on the ends to plug into the harness.
It will prolly be your best bet to buy from a vendor as they already have been proven to work correctly.
Dec 2, 2006
1,696
TN
I have the terminals. But, I don't like then dinky switches nor the looks.
Something like this would be nice:
attachment.php
