super diesel
<<<< Under Pressure
attaches horizontally through the back of the straight centerlink.
This is the offset I'm speaking of. I simply call it a dog leg. Sorry for the misunderstanding.
Does the SD Centerlink come with the puller as well or no?
I tested this by lifting up 1 wheel on the truck and pushing in on the front out side of the lifted tire. The CL rotated up and thus magnified the toe in effect. This is how I found it to be the original culprit of causing the serious toeing in without the bending of the tie rods. If everything is tight as you say, toe in has to let the material go some place. Some flexing is granted from the stock CL,,,, but that a whole lot of flexing if something doesn't give or move.
They hook up to the back side of the CL on the Kyptonite instead of the straight pointed out end. I will say offset if you prefer that. Geometry is simply geometry. Still the same thing. Being I did all the testing on the straight CL before I made it available in 04, I found quickly that I had no wander whatsoever with boosted launches with cranked T bars. Myself as well as others here have tested this theory time and time again on some of the most powerful dmax set ups out there. The only reason why you have wander with the strait CL during a launch is for the reasons of 1 or 2 tires spinning then getting traction and another tire or 2 spinning. Been there, done that for many years. If all tires spin or all get traction, it's a straight launch even cranked up (which I do not recommend anyway). My truck breaks all 6 loose during a hard launch in 4WD and moves side ways in the lane a little during the launch. I find shredded tire rubber in and outside of the wheel wells afterward. This is how I knew what it was doing. However, it launches very, very straight in line with out hardly any steering wheel input needed. I'm sure there are quite a few here with the same experiences with the straight CLs. Some folks here probably remember how I did the testing and what I've put my truck though. I do not wish this kind of testing on any ones truck.
Reading all this makes my head hurt, if I put a solid center link in my truck that has the tbars cranked, with tie rod sleeves will I be able to launch safely? Also will my tires wear weird?
running a special on the center link still
Anybody have any experience with these? They use the factory outter tie rod end but heim joint inner http://www.pure-performance.biz/
The thing with most of ones like KRYPTONITE they do not use stock tie-rods and little do you know how bad it suck to have one let go when 500miles away from home. Try and find a KRYPTONITE one at 4PM is some shit hole town. I will keep my sleeves and SCL that use stock GM Tie-Rods. Yes I know the "KRYPTONITE" have a "Lifetime warranty" but that does not help if the truck is down for days as they ship you new ones.
Chevy 1925 how have you been performing boosted launches @ track? I dont plan on doing this much but plan on giving her a few tries @ it. With a Billet or solid centerlink sleeves and my procomp lift with the supports will this be a problem? I dont have much of a cv angle it is pretty flat. I could do 80mph in 4wheel drive and the truck drove nice and straight but one time I tried to launch it in 4wd and it was like riding a bull! I am hoping the Straight centerlink and new pitman arm, idler arm, idler arm pivot and weld in bracket will allow this to be launched in 4wd.
