It's Alive.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
So what ALL was swapped to complete lbz stuff and what stuff from lly platform was able to be salvaged/used?!?!
This is pretty cool!!
If you have an LBZ engine and trans:
Driver's side ECM/TCM harness
ECM
TCM
Throttle pedal + harness
Shifter stalk
If you have an LLY engine?
Reluctor wheel
LBZ heads and injectors (you can just open up the injector bores .020" on LLY heads to accept LBZ injectors)
Engine harness
Not sure what all is different inside an LBZ trans. Probably need the valve body, NSBU?, and a new harness, and to install a RPM sensor.
motohed
dirty payback
Apr 15, 2008
486
escondido, ca
:awesome!!!! cant wait to see what those twins will put out!! i still cant get over the fab work of the first pics posted up of the piping for the turbos. that was some clean work:hail::hail
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
Congrats Pat, Kat and crew!
Now if I read the above post correctly...an 03+ LB7 to LBZ swap is possible then. Could I use LBZ top end and fueling and still use my LB7 bottom end :confused:
Tapshift on the steering wheel sounds awesome too.
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
:( It is kinda sad to see the Lilly go...........:(
But at least it gonna be faster now!:D
Oh ya, forgot......LB7's RULE!!!!
:eek::D:argue::stirthepot::poke::catfight::box: :angel:
Subman
Old Geezer
Jun 27, 2008
3,233
10
80
Madras, OR, Pahrump NV
Nice going Pat and gang. Who did the fab work on the twins and I guess I missed it, there is a tread on them that I also missed? I thought Casper was getting a stroker motor?:confused: Guess I'm really out of the loop.:banging:
paint94979
Beer Nazi
Sep 18, 2006
11,715
PPE made the twins... and Casper has an LBZ stroked motor:D
