It's Alive.
2,048
Good Luck, Pat, Kat and the crew....hope you dont have any problems. Now go out there and kick some salt!
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Casper lost all 4x4 pieces last month to reduce weight on the front tires. It now runs a 2WD LBZ trans with a 2-pc driveshaft.
The record for A/DT is an open record with a 135mph minimum at El Mirage, and no minimum at Bonneville. There was a 1947 Hudson with a 7.3 Ford engine that ran in A/DT at El Mirage, but he did not hit 135mph. Now the Hudson is in MDT due to some modifications that aren't permitted in DT class. There was supposed to be another A/DT truck showing up at Bonneville, but I'm not sure if they will make it.
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
Funny. Being that Casper originally was a 2wd...
:D
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Casper 1, never ran quicker 13.xx even on slicks. I blamed it on 2wd TCM/ECM issues (before EFILive), but when we swapped out the trans parts prior to trade-in, found it was bad ATS clutches. But it was too late.
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Wow, I have to check this thread more often. Casper having a stroker motor is correct then, and puts it in a different class? Have a back up 6.6 motor if you need it? Casper is now a 2x4 and will remain that way? Are Casper's drag racing days over at least as a 4x4? Am I up to speed now or am I still way behind.:D
