Half ton thread
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Been a long 2 months but the new engine will be ready to pick up on Wednesday.
This is a Dart LS next block, Callie's Magnum crank, Oliver rods, diamond piston bottom end. Heads are the AFR Mongoose LS7 casting. 427ci. Compression was bumped to 10.0:1
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
That thing is gonna make some f-ing steam Brian:thumb:
Sounds like an easy 1500 if you have the fuel system.
I seriously can't wait haha. The turbos will make some power for sure
Fuel system is definitely overkill... Twin -8 lines feed the engine from twin Magnafuel pumps, -12 return back to tank. The injectors are 250lb/hr and we will be spraying methanol to further stretch the power and aid in cooling prior to the water to air cooler.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
How’s the quality on the trick manifolds Brian? I’m looking at Trick, HSP and Performance Super Car.
My manifolds are cast... Had I known I would have went with HSP but I had second thoughts about doing their twin kit. I've never seen the PSC pieces.
