Engine Oil Cooler Kits
Interested in an Aux Oil Cooler Kit?
  • Yes
  • No
  • Why?
  • Waste of Time
Results are only viewable after voting.
Shenadoah75
Aug 27, 2024
3
FL
Reading your other thread I do think your EGTs are higher than they should be unloaded. What are you seeing empty on cruise for EGTs? This may be putting unnecessary heat into the oil, you also wouldn't be the first one with elevated cruise EGTs with Motor Ops tuning.
Exactly. I finally noticed this connection the other day when digging through every oil temp related post I could find. I will get a revised test on beltway when I can and report back. You have any other params you want enforced? Certain speed/rpm? Assuming tune 4 (sport economy) and letting it lockup in 6th gear is ok?
the fact I had the edge oil temp (in the cooler port) pegged at its max reading most of the drive from AL to central Florida has be worried. I don’t know just how hot above 300 it was. I should have bought an IR gun to check it.
I’ve got so much money into this build, it’s become a case that I have to make it work at this point. In hindsight, not sure I ever would have pursued it. It’s been 1.5 years of frustration and empty promises - great concept - endless execution trying to get there. Anyways…
As to the L5P, I wish I had never mentioned Banks. I bought the kit because I’m lazy to assemble separately and because of the oil temp port. Sorry feel like I took away from the post by mentioning it
Bdsankey
4,224
1,326
Larsen, Wisconsin
Exactly. I finally noticed this connection the other day when digging through every oil temp related post I could find. I will get a revised test on beltway when I can and report back. You have any other params you want enforced? Certain speed/rpm? Assuming tune 4 (sport economy is ok)?
Honestly you're looking for just some sense of average. I would guess that vehicle to be in the 600-700F area cruising on the flats. Any tune realistically is fine. I will say, SOTF is not helping you on this one. SOTF for an LML (on a high level) is nothing more than a digital throttle stop. A tow tune should have a vastly different timing curve than a max effort file, with SOTF that is not the case.
SOTF for 11-16 is nothing like a DSP5 tune for 01-10 since the earlier generations actually would have different tables.
I’ve got a so much money into this build, it’s a case that I have to make it work at this point. In hindsight, not sure I ever would have pursued it.
With an IR gun what is the pan temp and filter canister temp compared to the edge probe?
Personally I think the edge probe is to blame and may not be reading properly as that is very very high oil temp and I would imagine you'd see a major drop in pressure at that point to where it was in the teens. Is it the single wire or dual wire probe?
Nah, no worries at all!
Shenadoah75
Aug 27, 2024
3
FL
Single wire. I will say now that I have both a sensor in the cooler and in the pan , they seem accurate at start up/ambient and once warmed up, they’re fairly in sync with each other…
But let me get a gun, do some testing.
Reactions: Bdsankey
Shenadoah75
Aug 27, 2024
3
FL
Reactions: Dozerboy
Bdsankey
4,224
1,326
Larsen, Wisconsin
https://www.duramaxdiesels.com/forum/threads/fuel-cooler.38306/page-8
posts 152, 153, 162 (last one is from Chris)
This help? Wasn't kidding, I’ve literally been digging through every post I can find on temps since last year :(
I like the placement in post 152, that may be considered for sure! If so, I bet I'll have to use the larger setrab BUT it would keep things cleaner and out of the way.
Some high quality threaded inserts (rivnuts) and boom done.
All things to think on!
Reactions: Shenadoah75
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,400
Somewhere On The Ohio
www.marinemods.us
As most of you know, I run monster 3" dia by 24" long liquid to liquid to oil coolers on the marine builds. With the PPE 12AN block adapter, [which I have one that I keep kicking around under my desk if anyone needs] feeding the cooler and HP6 filter head. While I typically don't run stock water pumps, I've always thought that transfer tube assembly and brick left plenty of room for improvement within the constraints of the chassis.
And for size reference, my biggest issue I have now with oil, is getting up to a decent 190F without running the piss out of them. But in boat ya have a unlimited supply of 70F water flow thru the cooler, and no thermostat.
The other trick I've shared and do on any marine oil cooling upgrade is the Fuel Temp to Oil Temp Sensor mod. Somewhere here I posted the part# for off the shelf temp sensor with matching scale to OEM fuel rail sensor. Because fuel temp is not really used in the tunes, only as emergencey line pressure drop on fuel overtemp, yet that temp PID can be observed on any CTS or scan tool. Makes a clean and easy oil temp value on the dash, if ya have the correct hole for this ORB sensor.
1,117
No, because that's different from how Mike did his fuel cooler on the frame. Any way, did some digging and found the images are still up over on DP...
He used the seatrab brackets and just went straight to the frame for the Fuel cooler. In typical fashion the thread is useless but there were 2 images. He also states elsewhere after he stopped trying to offer them, this is the FP920M22I from Setrab.
I suspect An oil cooler could be done in this fashion as well.
Bdsankey
4,224
1,326
Larsen, Wisconsin
View attachment 125734View attachment 125735
I really like this mounting. I will need to verify space on an ECSB and RCSB but I would love to use the FP360S-M22I from Setrab in this location if possible.
Reactions: 1FastBrick
Bdsankey
4,224
1,326
Larsen, Wisconsin
Bumping this back up. Ordered the Setrab FP360S-M22I to test fit. It looks like the Fluidyne cooler will work BUT I really like how protected and out of the way Mike mounted the fuel cooler. The above PN has a MUCH higher BTU rating than the fuel cooler Mike spec'd.
FP920M22I (Mike's fuel cooler) has a heat rejection rating of 35-50k btu/hr
Core: 14.09in x 6.06in x 1.83in
Surface Area: 85.38in2
Core Volume: 0.55qt
FP360S-M22I (what I am planning to use) has a heat rejection rating of 56-78k btu/hr.
Footprint: 18.46in x 8.19in x 1.83in
Surface Area: 151.19in2
Core Volume: 1qt
Note, this cooler is not "published" at this value (it has no published value). What I can confirm is that Setrab claims it has the same BTU rating as their FP650M22I due to the internal turbulator design slowing oil flow.
I did also confirm that we should see a 3-5psi drop at 17gpm area with Setrab. While there is a pressure drop, I do not believe this to be an issue and they're one of the very very few companies willing to provide this information. For example, Fluidyne was unable to provide this number as was Derale other than "see our website" for generic information. That doesn't mean the Derale 65861 is out of the running, it just means it isn't my top contender at the moment. Setrab is proving to be one of the best vendors I've worked with as of late and can see why Mike worked with them in the past.
Also, on another fun note, I was offered the ability to pick up where Mike left off on the Setrab transmission coolers. That will be the next project, looking to see if I can dethrone Mishimoto for cooling performance while utilizing the same core for multiple units.
1,944
The older you get, the harder the hangover....know from experience. Hence why I dont drink much anymore.
Bdsankey
4,224
1,326
Larsen, Wisconsin
Lahey is a legend. I found out I apparently ordered myself more shots......................... I only remember ordering one round, I guess one round turned into 4-5...........
I completed my 3d print of my first bracket, will see today/tomorrow how they fit. I screwed up the first print hence the massive delay. With my ancient Ender 3 it takes ~3 days to print the brackets.
