Engine autopsy
dmaxalliTech
Shop Rat
Aug 28, 2006
129
Forged pistons need more piston to wall clearance than cast pistons (.008" on the Arias, .006" on the Mahle IIRC), which means that when they are cold they will be looser in the bore which will cause more wear on the skirts and cylinder walls. The Hellfire rings used with the Arias also don't last as long as a steel ring on a cast piston would. A forged piston will have the same drivability of a cast piston with the same compression ratio, but the engine will need torn down for new rings more often. The only time I would really recommend a forged piston is if you are going to be over 900 rwhp - that seems to be about the limit on stock cut and coated pistons. I also wouldn't get in a motor to do pistons without doing rods. If you are like me and "need" a daily driver that's over 900 rwhp you will have to decide if you want to replace pistons (and possibly have to over-bore each time until you need a new block) or if you want to replace rings - at over 900 rwhp nothing is going to last for hundreds of thousands of miles.
How dare you come in here and talk common sense:D
juddski88
Freedom Diesel
Jul 1, 2008
4,658
128
Chesterfield, Mass.
I guess the jury is still out on whether the Mahle Forged pistons are plenty adequate though. I mean, we've seen Pat's set that got really hot and failed, we've seen Matt's that failed due to heat via nitrous, I'm sure there are others that have failed but have they been failing because of inadequacy or because of unneeded abuse? Sure, they are more brittle than the Arias, that much I've learned, but if the Arias eats rings up and possibly bores too, why go through the hassle? Some have called the Mahle a "compromise piston" but until I see a situation where they failed or caused a different failure without extenuating circumstances I don't think that's a valid claim against them.
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
Man I know I will never be at a power level you guys are at that are cracking these psitons but boy does it worry me non the less. Dustin to bad you can't have a dd and a race truck.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
ok heres a thought.
what is bore diameter?
what is piston diameter cold?
what temp does the piston itself see at sustained wot under load?
how much does piston expand? ie piston hot diameter?
again i do not have a degree in chemistry or physics but just like thinking outside the box. i wonder if a slight overbore could help a little?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
drugs :baby:
bad tuning, bad injectors, holding it wide open for 120 seconds or something rediculous, you know.....unneccessary:D
Abby has used drugs had my bad tuning, kennedys crappy injectors!
It's been WOT for well over 120 seconds (you sure make a distance that way too:D)
I really dont see any of that as unnecessary,Perhaps thats just me though:D
juddski88
Freedom Diesel
Jul 1, 2008
4,658
128
Chesterfield, Mass.
haha, I agree, kennedy's injectors leave a lot to be desired I've heard; I can't say anything about your tuning but you haven't ran a 9 even after we all thought you would:joker:
the WOT comment was kinda tied into the bad tuning comment.
I just think that there is a way to make the Mahle's live...maybe i am wrong...but I'll let you guys know :) since I'm using them
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
What is unneeded abuse?
x2 - to get the type of power where you are even thinking about forged pistons I would say you are going to need some "unneeded abuse". Matt has had stock pistons last much longer than the Mahle forged pistons, he still hasn't sent them back to Guy to be inspected for cause of failure but 6 passes on $2600 pistons...... They'll live if you don't abuse them, but then again so will stock pistons.
I would rather replace rings than pistons - cast or forged. And like I said at 900+ rwhp you are never going to get everything to last forever - you have to decide what you would rather replace. You could make steel bearings that would last forever but they would tear the sh*t out of your crank. My vote goes to replacing the cheaper "wear items" like bearings and rings rather than replacing hard parts. Monotherm or monosteel pistons would be nice - you could have a steel keystone ring in them and not beat the ring lands up, but at the cost of a considerably heavier piston and about double the cost of forged pistons.
drugs :baby:
Nitrous is just a turbo in a bottle :baby: So are you gonna send your injectors in for testing every couple thousand miles? Get your truck set up to where stock tuning will do 900+ rwhp so that you can run "good, safe" tuning?
I wish I could afford to and talk my wife into it.
ok heres a thought.
what is bore diameter? Depends on if it's stock (4.055") or oversized bore
what is piston diameter cold? Depends on if it's stock or oversized pistons
what temp does the piston itself see at sustained wot under load? HOT!!!, some people peg 2000* pyrometers and that's not even as high as cylinder temps
how much does piston expand? ie piston hot diameter? Every time I try to get this measurement they cool off by the time I get the engine out and torn down:spit:
The different expansion rates of stock cast vs forged pistons is taken into consideration buy the piston builders. The Mahle forged pistons need .006" clearance, compared to stock that needs .0025", and Arias that needs .008". For a standard Duramax bore (4.055") the stock pistons are 4.050", Mahles should be 4.043", and the Arias should be 4.039". And the pistons are also tapered. You could have the engine slightly over bored to allow more piston to wall clearance but I don't think that the cracked pistons are a failing due to clearance issues.
The weight of the piston also makes high RPM a lot harder on the wrist pin holes, as do the extreme cylinder pressures you need to get 900+ rwhp; and every crack I've seen is parallel to the wrist pin.
Here is a good read: http://www.enginebuildermag.com/Article/1788/diesel_pistons.aspx
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
ok heres a thought.
Forgive me if this is dumb but would bore diameter change cold to hot following or receding from the piston ?
S Phinney
4,008
Quncy, Fl
I run .0035 clearance on my stock cut and coated pistons. After the coatings they gain about .002 in size also. So far I have gotten about 55k on the build but I not at 900 hp yet. Maybe this coming year i will get there.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
do you tune your own truck?
juddski88
Freedom Diesel
Jul 1, 2008
4,658
128
Chesterfield, Mass.
Simon, it wasn't a dig at you buddy, sorry if it came across that way. I was rooting for you and abby to hit it this year. Ive followed your threads from the first day I knew what a diesel forum was. I was actually not referring to abby or anything having to do with you when I first posted in this thread. It was more directed at caspers unfortunate failure as well as mats...which caused me to research the piston choices and pros and cons again (after buying the ones I have)
and to answer your question, absolutely not. I would probably have a set of melted pistons or worse if I tried to tune my truck myself right now, lol
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Pistons
I'm not sure some of you guy's are being real with your want's! You are NOT going to have a 1k motor and drive it like escort! You are NOT going to run 10's and NOT have to work on it! The Mahle piston will work for a daily driver/racer/puller and hold up FAIRLY well. Pat was doing something hard on a motor and nobody had really done until he did it with a duramax so it was a steep learning curve. It's hard that's why nobody had done it. He learned a lot and will benifit from it. Matt's truck (with stock pistons) had stock injectors. You can only get so much fuel from stock injector's! You add a bunch of nitrous with a limited amount of fuel it will live for a little bit. Now he is running stock pistons with big injectors so we will get a better idea of how long that will last. I hope it holds up well then all we need to do is put rods in these motors and let them eat. It would be a lot cheaper for everyone. If he gets a season out of it it would be stupid to build a motor! Get a stocker, put rods in it and have at it. Nothing will last forever no matter how much money you have or what supertuner you have or who you know! It's still mechanical and it will still break! Jeff
