Engine autopsy
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Trent, were those just stock delipped pistons? Hard to tell from the pics
Yes stock pistons that were cut .
Ok, thanks for clearing that up. Only the second set of delipped pistons I've seen fail.
To count all that I know of I would need to take my shoe's off :rofl:
Is it me or has every cracked piston I have seen has blown out on the corner of the wristpin pointing to the rear of the block?
That cant be coincidence:confused:
Every one I have ever seen was the same place , some worse than others but all the same. thats why I am buying forged pistons I have seen to many stockers fail , although they do last a while at decent hp levels :D
GeorgiaDieselGTO
Wants to drive his truck
May 12, 2010
102
Crossville
:) that is where everyone that i have seen blow out too.
ripmf666
15,123
14
47
Wentzville Mo
What's the difference that makes you say this? Just curious.
When you swap out the lbz rods and piston the extra weight from the when you add the heavier lb7 piston and swap to a aftermarket rod it's to far out of balance. The lb7 block your only changing the rod weight that's not off by much.
ripmf666
15,123
14
47
Wentzville Mo
I thought the LBZ pistons were heavier than LB7s?
I think I posted the weight of them before back when we built mine. I was joking while talking to Guy about how much weight they took out of my crank he said it was from the piston and rod swap.
GeorgiaDieselGTO
May 12, 2010
102
Crossville
If he took weight out of the crank that means you rotating asssembly weighed less than stock
juddski88
Freedom Diesel
Jul 1, 2008
4,658
128
Chesterfield, Mass.
Most of these have been stock piston with machine work, how about the mahle aftermarket cast piston that supposedly had more meat around the wrist pin IIRC?
ripmf666
15,123
14
47
Wentzville Mo
Yes found some of the info last night that we posted awhile back but iPhone battary went dead. The crower rods weight alittle less then stock and the lbz piston has more weight then the lb7 along with the wrist pin is also heavier. If you just swap out on a lbz crank your futher out of balance the doing this on a lb7 like Trent did.
mainer
Nov 11, 2008
326
so the lb7 and lbz cranks are different weights?
basically what your saying is that if you do rods cut pistons on lb7 your not that far out of balance and its seems as though it holds up fairly well. but on an lbz rods and cut lb7/lly pistons would be out of balance by a fair amount.
now another question whats the weight difference between lb7 and lbz rods??
HEEPJEEP
<--- Solid Axle "Leveled"
Mar 26, 2009
136
NH
Just balance the rotating assembly. Done.
Yep, needs to be balanced. :thumb:
TrentNell
Jul 7, 2008
7,543
slc tuah
My thoughts exactly
I guess i would have picked up several 10ths if i wouldn't have skipped that step , daaaaaaaang :(:rofl:
JK guys I agree its best but i see no real penalty from skipping it on my build. and for what the motor was built for . If it was being built for DD / 10's of thousands of miles , then yes , and if the crank would have been pulled it would have went out for a balance , but the crank never left the block.
2,101
Balance the motor. Its just a good thing to do. The shop that did mine had to use every weight they owned to get the crank right.
