What's this cam plate about and. Who makes it?
Um...GM/DMAX makes it.
Um...GM/DMAX makes it.![]()
Sorry Mario, I was thinking he had something aftermarket.
Its just the stock cam retainer. Josh's motor showed wear on the on the the backside of the retainer where the cam was walking to the front of the block.
[/IMG]![]()
Eric, I'm almost positive they were taken out, delipped and put on the new rods. I'm 99% sure I remember he even reused the piston rings. Hopefully he'll verify though.
Ok, thanks for clearing that up. Only the second set of delipped pistons I've seen fail.
Is it me or has every cracked piston I have seen has blown out on the corner of the wristpin pointing to the rear of the block?
That cant be coincidence![]()
Just dont try doing this with a LBZ crank :hug:
And where do you think Maximum stress is on the piston?
A while back I ran the stock pistons through an FEA program to try and understand the stress interactions and how delipping might help. A couple things came out of it. Most interesting to me was that delipping actually weakens the piston. The max stress point is more spread out however, and that might help if failures stem from a fatigue issue and not an ultimate strength problem.
Don't forget that delipping also reduces compression and thus the ultimate pressures the piston must withstand.
