Ive always done it the "flat tire" way, like Mike states.
Personally verified with pressure gauge that this way has "zero" cutback.
Ben
Ben
Is this right? I modified the stock valve from an 05 in the pics. Too much flat? Not enough?
Is this the same process with the transgo valve?I read in an earlier post about leaving the check ball out but is there more to it?
Yes it's the same thing.
If you leave the ball out of the Transgo valve you will need a longer spring to take up the slack left by the missing 3/8 ball. Otherwise the valve will rattle and the converter clutch may do strange things.
Thanks Mike!Il look for a spring.
Make sure the tension on the new spring is close to the Transgo spring.
I don't want you buying a garage door spring. :roflmao:
So does the ball have to be removed from the transgo valve and a longer spring installed? Or can you leave the ball and spring that comes with the transgo kit and just mod the transgo valve by grinding the flat on the end lobe?
so do I mod the transgo valve and leave the check ball in or just loose the ball?Thanks for the reply.swapping the built trans on the weekend so want to make sure I got it clear and don't f it up.
Thanks Mike. Any idea on where to pic up a longer spring with roughly same tension that is god for the heat?
Why don't you grind the valve and leave the ball alone?
Can you grind the trans go valve and leave the ball in it and accomplish the same thing as removing ball and getting a longer spring? If you can then I'll definitely do that but per what mike just posted above was remove ball and install longer spring
Sent from my DROID RAZR using Tapatalk
