Eliminating knockdown with the Transgo valve
xtremebikr04
Jan 17, 2011
573
Vermont
You did just a single groove? About how wide and deep did you go?
I did just a single groove 1/16" wide and 1/8" deep. Had the truck on a lift with pressure gauge screwed into test port and pressure didn't drop with tc locked. Now by the sounds I might have done it wrong.
15,681
Grind a 1/2 inch flat across the bottom land. Make it look like a flat tire. Not to deep.
I had Dave test the groove vs the flat on his dyno and we found most time the groove still had knock down.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
George Alexander also tested both versions about 5 years ago, not to take anything away from you Mike, but he found the groove, when done the way he explained to me, to work better for a couple reasons. To each his own I guess.
03spoolindmax
Nov 9, 2011
674
Mi
plug the end and cut a groove in the outer-most land parallel to the direction of travel. groove should only be 1/16" wide x 1/8" deep approx.
Tim
Are you both talking about modifying the same part of the valve? Tim is doing the outer part that the spring is against. Mike you sound like you're modifying the land that's on the opposite side or am I just reading this wrong.
15,681
F--k George and his bullshit testing.. Sometimes I wonder about you also.
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
LOL. Sometimes you are an ass, other times you are still an ass but a funny one. Lmao. But seriously, thanks for all the help and tech support you've given guys like me over the years! You really need to put a kit together!
15,681
It's being tested right now.
03spoolindmax
Nov 9, 2011
674
Mi
X2 mike definetly doesn't sugar coat anything. I'm sure he's just a big teddy bear on the inside :D
13,736
806
I don't see how a groove with the same amount of surface area removed from the land could be any more or less effective than grinding a flat spot. It seems to me grinding a flat is a whole lot easier to do than cutting a groove.
