Duramaxzak 2.6 pulling truck build
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Starting to work on the wiring and wondering what you guys are doing to kill power to the ECM? Is there a power wire I can put a switch in?
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Thanks for the links! I am running a air shut off, but would also like to be able to kill the motor from the cab if need be. I like the idea of tapping into the fuse spot!
ikeG
Oughta Know Better
Apr 19, 2011
2,472
152
Western PA
www.facebook.com
If you're running 10" Real wheels with 8" back spacing, you can run as small as a 7/8" spacer on the hub. I have a set i do not need any longer if you would like.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Yep, 10" wide with 8" BS Realwheels.
Pm me a price shipped to 55398! Not sure if I'm going to have time to get the rear axle welded in this year.
