That should really help cool the intake charge. :thumb:
It doesn't look like you were too tight on room fitting both coolers up front and you have your piping done but to give you more room in the front you could have welded both coolers together. Looks good and your truck is very similar in build to mine!
Looking good Zak, how are you cooling the trans oil?
I am not 100% sure on this, maybe some can confirm or tell me I am crazy, but you may want to put your water pump for your A/W on a separate switch. Something about running the A/W while trying to spool the turbo makes it harder and easier snuff out. I saw that bit of info somewhere while do some research on putting A/W on my truck.
I do believe that to be true about the A/W pump! Each item will have its own relay and switch. Just wondering more if its ok to switch the negative side of the relay or is the proper way to switch the positive side.
