Custom Cat twin Filter setup
durallymax
Apr 26, 2008
2,756
Under The Hood
Heres mine, 1R-0750 and a water seperator of a skidsteer that I cant remeber the number right now:D
Well it looks like a 1R-???? number on that seperator but all of our Cat SSL's run a 361-9555 which have the same filter base as the one you show. Ours are all 2012's and 2013's. The older 2011 we had used a different number filter. Same style setup just the slots for the keyways were different.
cat_dr.
257
Jackson,Al
I'm fixing to start gathering parts to build this setup I can get the filters and bases from work since I also work at a cat dealer. But what all line and fittings will I need?
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I used Arctic grade 1/2" Air/Fuel line, 1/2" compression & pushlock fittings , from the local hose & fitting store in town. 1/2" Compression fittings work perfect on the factory fuel line. I just used a mini tubing cutter to splice into factory line. 1/2" compression fittings can be had in any type of adapter fitting, so you could use any line you wanted. As you know, just make sure it's fuel rated.
What Dealer do you work for?
cat_dr.
257
Jackson,Al
I goin to order the ppe pump would the install kit they sell with it start in the the right direction? And I work for Thompson Cat
624
nice setup!
i got to get ride of this 80.00 OEM filter crap... i remember when they where 40 bucks!
though most of you run CAT i have a a baldwin version of the 0749 (BF7587) and a BF1259(cat number ???) dealer 10 mile from my house....
FWIW i run 2 mic for about 60-70k then change them. unles i get some dirty fuel
OnTheFritz
Sep 28, 2012
Butler, PA
These are some slick setups. How many gph pump would you need for 500-550 hp? I don't see me ever having more than that. What pump do you guys recommend?
