As posted in the new Cummins section of our forum
here is an update for you all
5.9L Update
Good news to report for the new year.
For those that are following development progress you might know that I am currently in New Zealand working along side Paul finalising the read and reflash process for the 2006+ 5.9L ECM (though I was told today some 2005's might be using this ECM too).
Anyway, the good news is we have got the in house beta software to the point of being able to bench read and reflash at least three of our test ECM's without any issues. Including recovery from purposely failed flashes.
Some people might be aware of the problem these ECM's have where they will loose the VIN and other important data after they have been programmed. This is actually a bug in the ECM itself, it's not the fault of any handheld programmers, not even Cummins (or Tech Authority seems to have a real solution to fix it either). However, we have come up with a reflash method that will restore the ECM's contents (that is usually lost) to a 100% duplicate of what it was prior to the flash.
For the rest of the week we need to test the licensing for the Cummins, try to get the Scantool talking correctly with the ECM and retest many GM controllers because we have made a lot of changes to the firmware and PC software. So if all goes well our beta testers will be tuning some Cummins ECM's by mid to late January. Beta testers, you will get an Email over the next couple of days explaining what is going on with the beta program.
6.7L Update
Once the 5.9L ECM product is released and stable we will move on to the 2007+ 6.7L ECM, up to at least the 2009 model before they put the RSA security in the ECM, that will have to follow later.
We are hoping to offer stable 6.7L ECM reading with the 5.9L release so customers can start sending in reads from 6.7L trucks.
Cheers
Cindy
