ive had to deal with II's lack of being able to clock injector bodies correctly in person as well. Its obnoxious.
You should have told them to stick those shirts up their buttholes :rofl:
I thought Randy built the heads for II???
Randy does good from what I've heard im buying his screw in cups and having a local shop machine some other heads
They either had a couple, maybe a dozen bad cores or the cnc program has or had a error in it, these heads cracked right at the thinnest section of the exhaust ports, I`ve got a cut away that shows the exact crack but its lent out to a guy right now for r&d purpose.
Now how do you explain a piston that looks like its been hit by a screwdriver or something, etched right through the coating..... II puts the heads on the motors at their shop as far as I know.
Randy is meticulous. When stuff comes from him it's exact and everything is done right. Those heads weren't right and one of them was screwed up to begin with. Randy doesn't do things that way......I'd be real surprised if they were from him. I think they were probably takeoffs that were laying around and came from some other scource, maybe even something they'd done themselves. The piston sounds like handling carelessness at II.
While Randy himself may have a good reputation, his shop and employees are not perfect, nobody is. A couple sets of delipped pistons were bought and installed up here in New England that were anything but perfect and protruded .018" out of the deck in some cylinders in 2 separate motors. Nothing against him personally, but that is not impeccable work
I've been to his shop a few times and talked with him a bunch. The shop is impressive and he's absolutely meticulous. I don't remember how much protrusion is on my engine. It's true that anyplace can make an error. But if a block isn't squared and exactly flat there can be several thou. difference in deck height from one end to the other, and between lowest - highest hole. That's why there are different gasket thicknesses.
