Converter lock up WITHOUT a lock up box
6,014
Just go to radio shack and get you two switches and some wire and you can build your own lockup switch. I do like how we are able to do it in tuning now but it doesn't seem reliable yet like a lockup switch
it works fine, just cause your not doing something right in the tune doesnt mean its not "reliable" ;). the switches also cause codes to come up and can burn out the solenoid down the road
quinton
1,883
Granbury Tx.
There is only three tables... One is enable/disable, other two are TCC slip... I'm pretty sure I can't screw that up. Maybe I just have to much POWA that it won't work through the tuning. Haha
meshanic
All In Trucks
Dec 9, 2010
436
West Texas
There's only three NEW tables with this update but there's a dozen or more tables that control TCC lock. After you disable the TCC slip inhibited lock you still have to correctly tune it to lock when desired. Just like all tuning it usually takes a few attempts to get the controller to do what you want it to. Trail & error before success.
6,014
yup. and if it locks my 800hp 7800lbs truck every time, it will do the same for high hp, lower weight trucks.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
All I did was disable it. Seems to works just dandy in my truck. But now you have me thinking....I may want to go back in and tweak it too see if im missing out on anymore awesomeness.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I went to the track tonight. Using the new tcm tune vs the bt lockup box. It was hot so im sure this screwed up the results but the first run of the day with no lock up box was the fastest pass i made all day. Next fastest run was with the lockup box. I ran 1/10th faster with the tcm tune than with the lock box.
thunder550
1,176
Phoenix, AZ
Come over and we will go for a ride lol
I call big spoon :woott:
Are you part of ADC on Facebook? Going to the meet Saturday night?
Are most of you just disabling the TCC slip inhibit and tweaking the apply tables, or are you keeping slip inhibit enabled and tweaking that?
6,014
No not going. Saturday is my moms birthday, I have to charge the a/c on my dad's 72 blazer, and my truck will be getting a good once over before our trip to silverton
