LMM: Built Motor
jckleewein
Dec 13, 2008
422
Broomfield, Colorado
I got the truck started this morning. The bad news is I have an oil leak. The leak is between the flywheel housing and transmission. I am pulling the transmission now. It looks like the lower oil pan can come off without removing the engine. Is this correct? What about the upper oil pan. Do I need to remove the motor to pull that if I need to.
custom8726
2,784
Upstate N.Y
I know on my 05 I can remove/change both the upper and lower pans with the motor in the truck, so I would assume you can with an LMM aswell but I'm not positive...
ripmf666
15,123
14
47
Wentzville Mo
It looks like the rear main seal is leaking.:mad:
I used the recommended tool to put the seal in place. Any ideas on what I should do to make sure the next seal doesn't leak?
Use some loctite around the crank to seal area this time as in the metal ring surface.
ripmf666
15,123
14
47
Wentzville Mo
After looking at it for a little longer last night I think I can do the same. The front bolts on the upper pan will be a PITA, but it can be done.
I know on the LBZ and older truck you can drop the center cross member under the pan and the pan will drop down think there is 4 bolts 2 on each side.
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
X2 on the rear main am this the rear main is hit an miss my first one leaked pulled the tranny second is going good I used a piece of 4 PVC pipe to insure it was snug lol I didn't.want to.buy a 500 tool
jckleewein
Dec 13, 2008
422
It's a pain to get the transmissions out since I have twins and headers. I have to remove everything on the PS to get where I need to get. I don't like the sounds of hit and miss with the seal, but I guess thats the nature of the beast.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
You should have tried to buy jaydcc69's lmm motor instead, you would never need to work on it, it was keep in great condition and recently powered his truck to 7.67 1/4 mile fuel only with a vgt
