Broken Crankshaft Count?
Please pick the one that you had break
  • Total voters
    185
9,905
151
First #4 break I've seen.. In a core engine I picked up. Never enen noticed till pulled mains to lift out..
Someone please bump lbz/lmm count by 3 for me. That's how many we have seen hit the floor in past 2 months...
Sent from my SAMSUNG-SM-G870A using Tapatalk
Broke my LBZ at #4.
Sent from my D5803 using Tapatalk
Dallas S
486
33
Alberta
have two motors sitting here broke at #4(one being Dales)
two lml's and one lbz broke at #1
and one lmm broke at #2
need to start trashing these cores lol
56taskforce
1,090
70
Add another LBZ to the count, mine let loose this morning. Guess I am in the market for a fix maybe an LMM short block ???
6,092
By the looks of all the fasteners and the rtv application, nothing would surprise me. Member on here bought the truck used and had to straighten bunch of stuff out to even get it to run. Then breaks crank first pass out.
Sent from my XT1585 using Tapatalk
wow! id be pissed!!
caseih03
Dec 12, 2016
13
Probably main cap/block fitment issue. Caps to small/blocks too wide, cap walks, spins main bearing, makes crank brittle, now your crank is a 2 piece.
dirtymax36
2nd place is last
Apr 11, 2013
367
Has anyone had any failures or can name and “cons” for the new callies durastar crank ? Other than it needs to be properly internally balanced to your rotating assembly. Seeing if there’s any failures before purchasing.
9,905
151
I don't think there are enough of them out there to say either way if they are worth it or not or any better than the other more popular options that are out there.
