Ok so I’m finally happy with my brakes. Just got the LML master cylinder on and I’m impressed. Much less pedal travel. The brake pedal is slightly harder, but I have much more confidence driving. Getting it to work is a pain in the ass but shouldn’t be bad now that I’ve figured it out.
Get an LML brake master cylinder. Find a metric double flare tool. Find 14mmx1.5 inverted flare to 6mm tube fittings. Drill out the fittings with a 17/64 drill bit. If your fittings aren’t threaded all the way to the top. Cut off the top and and use a drill bit to bevel the fitting. Cut only the flare off of the factory lines (make sure you cut it straight) remove factory fittings. Install new fittings, and flare the line. Install everything :thumb:
